Need help with wiring an is250 steering (NYC)
Is there anyone in the Tri-state area (nyc) that have done the wiring for the horn, cruise control an radio on their sc300 using the is250 steering wheel. I have already swapped the igniter with the is300 igniter. Please let me know. I'm willing to pay someone that have done it before. Thank you
Vin Starz.
Vin Starz.
For the cruise control, you would use your original one in your SC. This should bolt on/off-at least the steering wheels that I've replaced. The horn wiring should be plug and chug as well-just take a look at how your horn in your current steering wheel is wired-worse case you'll need to solder the wire. Everything else is a no connect
ok cool. i will look into it this weekend. Do u have any pics or diy of doing wiring for the horn. So the cruise control i will try an use the one on my SC. I'm guessing i'm using the original sc300 clock spring also. Thanks for the help so far.
That airbag is dual stage, so you'll have to change out connectors and it should work. Get an is300 or similar airbag connector from a scrapyard.
Here's a writeup on swapping into a supra, probably more in depth than you plan on doing, but good information:
http://www.supraforums.com/forum/sho...etrofit-How-To
edit: not sure if links are allowed, let me know otherwise.
