93 sc400 ac light blinking
He all, on to the next issue. The ac is not working in the sc I just bought. I tried adding Freon, but it seems there was already pressure in my system as the low side read 70 psi and the high side was at about 120,(compressor off) that should be enogh to operate? I did try to add r134 but the compressor would not stay on long enough to retrieve any. where should I be looking? p.s comp will kick on if someone taps the button on the dash, but only for a second, then right back off..
I have had the same problem. It was as simple as resetting a switch but I have mechanics who
do the work so regretfully I cannot tell you exactly how. I will get to my Lexus guy and
post the solution. In my case simple.
blkstealthpaid4
03-21-02 07:51 AM
