SC- 1st Gen (1992-2000)
How did they pull this off?
Old 01-09-15, 11:03 PM
tfwnoturbo
tfwnoturbo's Avatar
Default How did they pull this off?
Does anyone know how they made the dash look so smooth? It looks as if they wrapped it with leather or something like that. I have a gaping hole in my dash right now and I'm itching to fill it, but I don't know how to go about it. Anyone here done one of these types of things?
Old 01-09-15, 11:59 PM
t2d2
t2d2's Avatar
I don't know if they refinished the dash and glove box, but it looks pretty stock to me. I'm guessing it's a '92 with no passenger airbag, and they just replaced the wood trim with a nicely fiberglassed gauge cluster. Pretty creative use of the space, I must say.
Old 01-10-15, 12:42 AM
oldManTan
oldManTan's Avatar
definitely must be a 92 since no airbag, but that can be easily molded with fiberglass and lots of sanding/body filler.
Old 01-10-15, 12:26 PM
tfwnoturbo
tfwnoturbo's Avatar
So, how would someone go about doing it? Is there any way to just close up the airbag's hole? I'm thinking about getting some zipties and drilling holes. Any better suggestions?
Old 01-10-15, 02:28 PM
HiPSI
HiPSI's Avatar
That looks incredibly clean however function wise for the driver how the hell are you going to watch those gauges while going WOT lol ?!
Old 01-10-15, 03:01 PM
t2d2
t2d2's Avatar
That was my initial thought, but then, how often do you really need to see the gauges once everything is set up and working properly? Some people mount them in the glove box, which is even less visible with the worse angle.
Old 01-11-15, 08:33 AM
Luxor
Luxor's Avatar
I have a gauge in my dash right there and I have no problem seeing it from the driver position.
Old 01-11-15, 12:21 PM
Bankswood
Bankswood's Avatar
well it has a cup holder and the 92 did not. Unless he added it .
Old 01-11-15, 02:09 PM
t2d2
t2d2's Avatar
That's an extremely small asterisk, IMO. I added the dash cup holder to my '94, and I haven't dreamed about doing anything as extensively detailed as that fiberglass work. If you have the stereo surround out already for other work, it seriously only takes a couple seconds to do.
Old 01-12-15, 07:49 AM
OBEEWON
OBEEWON's Avatar
If you are watching gauges at WOT you might be doing it wrong.
Old 01-12-15, 08:03 AM
irondonkey
irondonkey's Avatar
well... it would be good to have a quick glance at them.
mainly boost and wideband levels.
i'd sure as hell be looking at the wideband while going WOT. the last thing i'd want to see is a 15.0 AFR.
Old 01-12-15, 10:43 PM
sfgsdfg999
sfgsdfg999's Avatar
If you remove the airbag assy, you can detach the front pieces. They're held on with nuts. Deploy the air bag, remove it from the the metal enclosure then bolt the front (or whatever mod) back on to the just the metal enclosure. Then everything bolts right back up and looks unmolested. Take ESD precautions!
Old 01-12-15, 11:18 PM
t2d2
t2d2's Avatar
Seriously? I'd much rather disconnect the battery, wait a few seconds (or minutes), and remove the airbag intact than be hit in the face by another one. And you can make a few bucks selling it if it hasn't been deployed.
Old 01-20-15, 11:20 AM
sfgsdfg999
sfgsdfg999's Avatar
I took that for granted that you would fully discharge the system before removing the airbag assy. All this is after you take it out. Next time I'll be more thorough in description. I would never buy a used airbag - imho.
Old 01-20-15, 12:40 PM
t2d2
t2d2's Avatar
You changed your choice of words from deploy to discharge. See the difference?
Quick Reply: How did they pull this off?
