92 SC400 with 243,000 miles
what year is your car?
1993 SC400 with 243,000 miles.
List of repairs & mileage:
Drivers side door seal 20,000 (warranty)
Radiator reservoir 54,000 (warranty)
K&N air filter 60,000
Dist cap & Rotor 80,000/167,000/237,000
Spark plugs 80,000/167,000
Rear brake pads 92,000/232,000
A/C LED backlights 110,000
Instr cluster bulbs 110,000
Front brake pads 128,000
Driver side window regulator 129,000 (regulator & motor)
A/C compressor 157,000
Trunk lifts 158,000
Antenna 163,000
Alternator 166,000
Pwr steer pump 166,000
Tim Belt/water pump 167,000
Front lwr control arms 168,000
Front up control arms 209,000
Steering tie rods 209,000
Front stab links & cushions 209,000
Rear stab links & cushions 213,000
Rear upper arms 216,000
CV boots 216,000
Radiator & hoses 217,000
Transmission rebuild 230,000 ($1650)
Starter 237,000
Note:Starter was still good, but rear water bypass joint flange was leaking coolant, so replaced starter also.
Inst panel needles 240,000 ($$$$)
Routine Service & mileage:
Transmission fluid 22,000/50,000/90,000/136,000/185,000/220,000
Differential gear oil Mobil 1 75W90 20,000/50,000/125,000/165,000/220,000
Oil Mobil 1 5W30 & Filter Every 10,000 miles
STP fuel system cleaner Every 10,000 miles
Tires 35,000 to 45,000 miles
Note: Did work myself except, timing belt, transmission rebuild & rear upper control arms/cv boots.
Avg MPG 22.52, Max 26.0 MPG, Min 18.0 MPG, primarily highway driving, runs great, looks great
Trunk lifts 158,000
Antenna 163,000
Alternator 166,000
CV boots 216,000
Starter 237,000
I traded a 1993 honda civic with an integra motor for it straight up. It has a lot of miles but its still a lexus. I have to change the usual stuff. The alternator and power steering is messed up and the car is painted bright metallic orange. other than that its in good shape. I think i got a good deal considering my car was only worth like four grand.
sckidnyc
SC- 1st Gen (1992-2000)
13
11-23-06 11:24 PM
