SC- 1st Gen (1992-2000)
projector lense is loose?
Old 01-30-15 | 10:00 PM
SC3coupe's Avatar
SC3coupe
Default projector lense is loose?
The low beam socket has a little play and you can see the "globe" inside the headlight wiggle when I move it by hand.. I don't notice it when driving but it's probably annoying to others.
The other side is fine, feels like a stiff rubber is holding the lense, The bad side has play.
Does anyone know how to fix? There is a big rubber ring 81518B on the back that says "open" with an arrow it is on full clockwise already.
The alignment screw vertical and horizontal works so I don't think anything popped loose inside.
It I hold the long up/down adjust screw tight by hand then the play at the socket almost goes away.
Thanks
Old 01-31-15 | 12:01 AM
OG Dada's Avatar
OG Dada
The projector is held by 2 long bolts. The same bolts you use to adjust it's focus. If you have/had condensation in it, those bolts easily rust out and eventually, nothing is keeping the projector in place. Just buy a used headlight in better condition, or do a retrofit on both if you want better projectors.
CDubGS
06-22-10 11:43 PM
kyoso23
10-16-08 11:57 AM
The G Man
GX - 1st Gen (2003-2009)
14
11-30-07 11:26 AM
KPC
IS - 1st Gen (2001-2005)
04-02-07 10:33 AM
Sleeper97
Lighting
03-16-05 12:05 AM
