SC- 1st Gen (1992-2000)
is $160 to much for a wheel alignment?
Old 03-04-15, 02:57 AM
DrMcPho
DrMcPho's Avatar
160 is absurd. I paid 100 at a tire shop, if you can, just ask around your area or people you know and see where they go.
Old 03-04-15, 09:04 AM
Kris9884
Kris9884's Avatar
Depends. I paid Firestone $160 and I now have lifetime alignments for as long as I own the car.. If you are just going once it shouldn't be over $100 unless maybe if they are picky about asking for specific settings or something.
Old 03-04-15, 10:08 AM
1A1
1A1's Avatar
Depends on the shop. Hi performance shops will charge more if you want a custom alignment. I personally don't mind paying a bit more for a job well done.
Steve
Old 03-05-15, 01:06 AM
Equalizir
Equalizir's Avatar
Wow thanks for all the input. I'm definitely going to shop around. The car is currently lowered an inch. Putting coilovers on later this month but the most I'll go is 2" total. Just trying to minimize the fender gap. Don't have the car right now cuz it's currently getting painted. I'll be able to pick it up this coming Monday. But thanks guys again for the info.
Old 03-05-15, 07:00 AM
net4n6
net4n6's Avatar
Originally Posted by t2d2
For $160, you can get the lifetime alignment deal from Firestone and get it tweaked weekly for the next 10 years, if it suits you. The local place is always happy to align to custom specs and has never mentioned my other car being lowered as an issue.
I paid around $125 6 years ago for lifetime alignment at Firestone for my lifted 4runner. I went offroad a lot so it worth it for me. I am still using it.
Old 03-05-15, 08:46 AM
t2d2
t2d2's Avatar
I'm guessing you got lucky with a promotion? The price I paid a couple months ago for my SC was within a couple bucks of what I paid 10 and 20 years ago for the other two cars' lifetime alignment deals there, as I recall. All in Oregon (two different shops in two different cities), though, so maybe rates differ by area.
Old 03-05-15, 09:20 AM
grumpi300
grumpi300's Avatar
be careful with firestone lifetime alignments though. I work at one, and the one I work at only does toe and go. doesn't touch camber or caster even if its super easy. only reason they did mine is cause I work there and watched my mentor do it. (I don't feel comfortable doing alignments yet.) but yeah if you get the lifetime alignment at firestone, depending on the shop, they only do toe.
Old 03-05-15, 10:01 AM
Equalizir
Equalizir's Avatar
Wow that's good to know. Thanks!
Old 03-05-15, 12:38 PM
t2d2
t2d2's Avatar
I would really hope that's specific to your shop. How would they meet factory specs?? And if they aren't, then wouldn't they be open to huge liability issues? The Firestone shop here gives a detailed printout of all the factory specs and how close they were able to come to each one.
Old 03-05-15, 03:12 PM
Ali SC3
Ali SC3's Avatar
its not specific to any shop if you encounter a place that is "too busy" to give you the printout that means they probably didn't do the job right. ask for the printout up front before the job is even started. that way they wont even try the excuse on you later.
the only reasonable excuse that the tech can give on a printout is that the before numbers are not the starting numbers because they change the settings a few times before they get it right, but you should be able to see you have the final numbers you want. if you get the numbers you want on the final it doesn't matter much what they did to get there (unless it was nothing.. lol).
That is what you can look out for as a potential customer. And some places can still mess it up even when all the numbers are in spec cause the specs have such a wide margin at least you will know it when you see the printout and I usually try and get the lance alignment done. if the shop can't handle specific alignment numbers then its probably not the place you are looking for long term.
VQT
LX - 3rd Gen (2008-2021)
18
09-28-22 06:07 AM
Lveyolfe
01-20-15 10:49 PM
saewoo
06-16-14 03:59 PM
daddyswang
GS - 1st Gen (1993-1997)
11-10-09 09:55 PM
Quick Reply: is $160 to much for a wheel alignment?
