SC- 1st Gen (1992-2000)
How many people have Dash Needles that don't work ?
Old 04-17-03, 03:33 PM
  #46
L.A.Rue
L.A.Rue's Avatar
My speedo and tach needles flicker for few moments then only partial light up. My Temp and fuel are fine.
L.A.Rue is offline
Old 04-17-03, 04:46 PM
  #47
joeyc2
joeyc2's Avatar
mine are completely out!!! but who needs them!
joeyc2 is offline
Old 04-17-03, 04:49 PM
  #48
CapnHal
CapnHal's Avatar
My SC300 has 116,000 miles, speedo needle light just failed, tach still shows but has some dark spots.
CapnHal is offline
Old 04-17-03, 05:06 PM
  #49
nextlevelcoupe
nextlevelcoupe's Avatar
Originally posted by onelasttry
from what i've read, they don't offer anything yet. just a prototype done so far. i suppose if you like the rice look, it's personal preference. as far as the price worthiness, it's worth whatever you are willing to pay to get it. my electronics distributor shows the cathode tubes @ $10.83 each. factor in what you are willing to pay for labor and you got your price. i personally do not know the guys there and have not seen the work or build quality.
great!!WE HAVE A CERTIFIED ELECTRICIAN ON BOARD.....it's good that i can maybe finally get an assist on this project...i have the cathode tubes from an ls 400 the ones that backlight the display(tach and gas)and i am trying to find a way to ignite them..any suggestions???first of all,12v direct will not work.i understand i need an inverter to kick up the voltage to get it to work,but where can i find one applicable to this project?also,where did you get that quote for those cathode tubes??
here's a pic of the cathode tubes i will be working with....
Attached Thumbnails How many people have Dash Needles that don't work ?-cold-cathode.jpg
nextlevelcoupe is offline
Old 04-17-03, 05:25 PM
  #50
CapnHal
CapnHal's Avatar
onelasttry:
Would you mail me the link to the pic sent on 3/24? Thanks.
CapnHal is offline
Old 04-17-03, 05:30 PM
  #51
O. L. T.
Keeper of the light
O. L. T.'s Avatar
i no longer have a link to pics due to my image host clipping my wings for remote linking. if you will specify the image you need, i'll arrange for it to be sent to you.
nextlevelcoupe- go here and download the catalog and within it you can find the ballast to fire the tubes plus a killer selection of tubes also. you'll notice they all run around 10 to 13 bucks each. there is rarely an exception.
http://dkc1.digikey.com/us/pdf/T031/Catalog.html
O. L. T. is offline
Old 04-17-03, 05:31 PM
  #52
O. L. T.
Keeper of the light
O. L. T.'s Avatar
nextlevel i was passing out a link to some images i hosted, but the image host went south.
O. L. T. is offline
Old 04-17-03, 05:34 PM
  #53
CapnHal
CapnHal's Avatar
onelasttry:
Reference was to your post of 3/24 where you had circled a couple of areas on an image to look for problems on needle illumination. Thanks.
CapnHal is offline
Old 04-17-03, 05:38 PM
  #54
O. L. T.
Keeper of the light
O. L. T.'s Avatar
gime a minute and i'll put it in my gallery on this site and post the link here.
O. L. T. is offline
Old 04-17-03, 05:39 PM
  #55
nextlevelcoupe
thanx a mill!!
Old 04-17-03, 05:48 PM
  #56
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Ta DAaaaaaaaa
https://www.clublexus.com/gallery/sh...hp?photo=10546
replicate the repair on the other side also. this is one of the only pics left after the image host dumped my files. lucky i saved this....
nextlevel, your welcome. why be greedy ... ya know? enjoy.
some people can do this repair, some can't. i've done quite a few.
O. L. T. is offline
Old 04-17-03, 05:54 PM
  #57
CapnHal
CapnHal's Avatar
thanks onelasttry, you da man.
CapnHal is offline
Old 04-17-03, 08:54 PM
  #58
O. L. T.
Keeper of the light
O. L. T.'s Avatar
wanna see some cold cathode tubes in action? check this out. these are the switching tubes. as little different, but very cool.
http://www.vintagecalculators.com/ht..._dekatron.html
so whats the benefit to a switching tube?
They are much cheaper than either semiconductor devices or vacuum tubes; they do not require costly materials with a high degree of purity in their manufacture, nor do need transformers or cooling systems to operate. The tubes require no warm-up period and they can take severe overload."
no inverters, ballasts, or otherwise. this is the problem with the Lexdash design. they can't get them calibrated because they are using the non switching cathode tubes. it helps to know your options
O. L. T. is offline
Old 04-17-03, 11:27 PM
  #59
jacabal
jacabal's Avatar
"replicate the repair on the other side also. this is one of the only pics left after the image host dumped my files. lucky i saved this....
some people can do this repair, some can't. i've done quite a few."
onelasttry - Since you've done quite a few of these before, what would you charge us to repair ours if we sent you the dash? I'd think quite a few people would be interested. Crunch some numbers, and let me know. I'm sure that on some dashes you'd just need to replace the caps, others may need resistors also, and maybe some are unrepairable. How about charging a basic service fee, and then if something else is wrong go from there.
Thanks
jacabal is offline
Old 04-18-03, 07:15 AM
  #60
TexSc
TexSc's Avatar
Default BLUE
hey guys..... cheack this thread out
https://www.clublexus.com/forums/sho...t=backlighting
or
http://photos.yahoo.com/bc/weatherm...otos.yahoo.com/
or
https://www.clublexus.com/forums/sho...threadid=75721
its for a Is300 but ive benn trying to ask the guy if he can do it for sc's. No response so far. He is goin to release a DYI kit for Is though so maybe one of us can get it and see how it can be modified to fit the sc (maybe at a lower price then $350??) its not for just the needl however but for the whole inside of the car(better then $500 !)
good luck tech's
TexSc is offline
Quick Reply: How many people have Dash Needles that don't work ?
