SC- 1st Gen (1992-2000)
Soarer r154 tripod swap with soarer front drivevshaft..hitting on cup
Old 04-29-15, 08:28 AM
CatManD3W
CatManD3W's Avatar
Default Soarer r154 tripod swap with soarer front drivevshaft..hitting on cup
here are my specs...
Aristo 2JZGTE
Soarer r154 tripod
Soarer r154 front shaft with SC300 rear shaft
Stock SC300 rear diff
I found this other post that seems to be similar to what I am experiencing...https://www.clublexus.com/forums/sc-...-my-trans.html
So I completing my tripod soarer r154 swap and noticed upon installing driveshaft that it is hitting on the cup/dustshield on the back of transmission when I spin the driveshaft...Could this be an issue or not? (The cup is not bent or mishaped at all)
Could I cut down the cup by say a 1/2 inch....so it wouldnt hit?
I replaced my stock w58 front shaft with the soarer r154 front shaft...and swapped over carrier bearing.
The driveshaft also is all the way in on transmission....and it was very difficult to get in...could this cause binding issues?
All the holes for mounting carrier bearing are lined up perfect and same for crossmember.
SC300 W58 front shaft (TOP) and Soarer r154 front shaft (BOTTOM)...the soarer r154 appears to be a little bit longer...
Soarer r154 front shaft (LEFT) and SC300 w58 front shaft (RIGHT)
Here is the installed pics and closeup of what I mentioned above...only need about 1-2mm more of clearance and it wont hit on the cup..could it be that the driveshaft is to far in the back of transmission
CatManD3W is offline
Old 04-29-15, 10:21 AM
gerrb
Super Moderator
gerrb's Avatar
probably at least 5mm to clear that whole U-joint. IF that front shaft was originally mated with that R154 then it's your shaft that needs to back out a bit ..
gerrb is offline
Old 04-29-15, 10:29 AM
CatManD3W
CatManD3W's Avatar
I purchased this setup from Omar....and he had indicated that he ran this exact setup in his car with no issues....
Omar can you comment?
Old 04-29-15, 10:42 AM
gerrb
Super Moderator
gerrb's Avatar
either your second half or that front half part of the driveshaft needs to be cut / trimmed a bit to move that thing backwards and clear that shield
gerrb is offline
Old 04-29-15, 11:55 AM
CatManD3W
CatManD3W's Avatar
After taking measurements
Soarer r154 front shaft = 25 in
SC300 w58 front shaft = 24 3/4 in
MKIII front shaft = 24 3/4 in (thanks for the measurement Gerry)
The soarer front shaft is 1/4 to long....
So my options are to take it to a driveshaft shop and have it cut down or to try and source a MKIII front shaft
Old 04-29-15, 12:55 PM
mikef
mikef's Avatar
why dont you just remove the cup, it really no point in it
mikef is offline
Old 04-29-15, 01:37 PM
CatManD3W
CatManD3W's Avatar
Its not quite that simple the driveshaft is all the way in at back of transmission....it needs to have some play in it....they way it is right now there is 0 play in it
Old 04-29-15, 01:40 PM
KahnBB6
KahnBB6's Avatar
Received 1,243 Likes on 866 Posts
I had the same issue with my MK3 R154 swapped with an MKIII R154 SC front shaft. The metal protective cup on the back of the R154 was hitting so badly it was mangled and had to be removed. I still haven't replaced it. Probably should order one.
I at first assumed that my original SC300 carrier bearing might have been bad... but this wasn't the case.
No issues any longer without the cup but it I also wish I knew why this happened.
KahnBB6 is offline
Old 04-29-15, 01:43 PM
CatManD3W
CatManD3W's Avatar
How far in did the yoke go into back of transmission....?
Old 04-29-15, 03:19 PM
gerrb
Super Moderator
gerrb's Avatar
Isn't the shield / cup used to prevent splashes of water getting into the end of that driveshaft / transmission to prevent corrosion / rusts ?
Pretty sure there was a good reason why Toyota installed that shield ./ cup .
gerrb is offline
Old 04-29-15, 03:20 PM
CatManD3W
CatManD3W's Avatar
I figured out the issue was a combination of a few things....the rubber flange on diff didnt get seated properly in the holes....I also did trim about a 1/4 in off the cap/dustshield....
It now spins freely without any contact or binding....
Old 04-29-15, 07:59 PM
INTIMAZY
INTIMAZY's Avatar
I had the same issue. Would have sworn it was perfectly straight.
It wasn't.
Took it off and stood it up on the table and watched it rock back and forth. It might notnhave been bent much but it definitely was.
I havne't had mine back on in almost 3 years.
INTIMAZY is offline
Old 04-30-15, 05:07 AM
99SC42
99SC42's Avatar
Ryan,
Sorry for the late reply..Just like I was asking you yesterday if the dust shield was bent..in my opinion it looks like it was bent. That driveshaft is a soarer driveshaft not MK3, MK3 driveshaft is bigger in diameter and a little short.
Do me a favor, pop the dust shield cap off and install the driveshaft, Ill order you a brand new dust shield and mail it to you.
I used this driveshaft on my MK3 r154 without the dust shield, because the first driveshaft I had on the you bought from me had a bad U joint on the Front half shaft..
Let me know how it goes.
Sorry for any inconvenience this may have caused.
99SC42 is offline
Old 04-30-15, 02:41 PM
CatManD3W
CatManD3W's Avatar
Originally Posted by 99SC42
Ryan,
I could imagine if you had a bad u joint on the front shaft it would bend the cup/dustshield
Thanks Omar I will send you a PM with my address..
Old 05-03-15, 12:40 AM
Cleanshots
Cleanshots's Avatar
thats too far in for some reason man.. its not suposto go that car in the cups should be flush the yoke stay outside all the way..
Cleanshots is offline
Quick Reply: Soarer r154 tripod swap with soarer front drivevshaft..hitting on cup
