Supra Exhaust on a SC300 - FINAL ANSWER!
Here is the final answer as to if the supra exhaust will fit on a sc300. IT FITS, but it IS NOT a bolt on affair. Here is a page i created to chronicle the process of fitting it on. The exhaust is an Apexi N1 Stainless designed for a mkiv supra. Enjoy...
http://www.brevardmotorsports.org/supraexhaust.htm
-Matt
-Matt
If you or any one else is looking for a complete bolt on, single sided, exhaust system for the SC300, HKS has two systems: The Hi-Power and the Drager.
These two are not normally stocked at the moment, but have been brought in on special order basis.
The Hi-Power comes with 75mm diameter piping with a 120mm tip
The Drager comes with 85mm diameter piping with a 120mm tip
I have brought in the Drager for friends SC that is now powered with a GTE motor.
He ran the exhaust when he was on the stock GE motor and it wasnt bad at all.
If you have any questions, let me know and I will see what I can do the help
Will
Will
Dms3603
Performance & Maintenance
12-16-11 05:15 PM
