SC- 1st Gen (1992-2000)
Battery Discharging
Old 05-16-15, 05:46 PM
E36M3
E36M3's Avatar
Default Battery Discharging
My battery indicator light is on. I checked my belt and it's tight. I don't wanna take it to an independent shop until I check it so I need yourr help on what to look for. Money is tight so please help. Appreciate it!
Old 05-16-15, 06:40 PM
gerrb
Super Moderator
gerrb's Avatar
Battery indicator light being on can mean your alternator is not charging the battery.
Go to autozone where they can check your alternator for free. Just tell them to check out the alternator . If alternator is not charging the battery , soon you will have a dead battery.
Old 05-16-15, 08:00 PM
E36M3
E36M3's Avatar
gerrb,
I just had my battery tested and its measured 362 cold cranking amps it is rated at 625 cold cranking amps and it says battery replacement is highly recommended. A starter test shows the voltage is 11. 30 volts and 53.2A. I unplug the positive cable from my battery while the car is running and it died. What does it say battery replacement or alternator replacement?
Old 05-16-15, 08:19 PM
TokinSC400
TokinSC400's Avatar
Time for a new alternator, E36M3.
Old 05-16-15, 08:50 PM
E36M3
E36M3's Avatar
Thanks for the help guys. I appreciate it.
Old 05-18-15, 10:18 PM
E36M3
E36M3's Avatar
Reporting back. Installed new Denso alternator. Everything is good. I would like to thank everyone's help. Appreciate it!
Bettaworld
05-03-17 01:23 AM
masboy
03-04-12 06:37 AM
OBEY414
Performance & Maintenance
11-21-11 02:12 PM
melissac
07-19-10 03:15 PM
2ya
08-02-06 04:50 PM
Quick Reply: Battery Discharging
