SC- 1st Gen (1992-2000)
A/C blowing cold out of pass vents, warm out of driver's vents.
Old 06-12-15, 02:15 PM
estomax
estomax's Avatar
you can test the heater control valve by pulling the vacuum hose out of the plunger and seeing if it opens (hot water going through heatercore) and then putting vac to it which closes it (hot water not going through heatercore).
a simple diagnostic step anyway...
Marko
Old 06-13-15, 10:34 AM
Aron9000
Aron9000's Avatar
Marko
Its not the heater control valve. I had somebody sit in the car and turn the **** from max cool to max hot, back and forth. The little servo motor works fine.
I'm having the a/c on the house serviced next week, preventative maintenance. The guy said he'd hook up his gauges to my car and let me know if I'm low on freon, and hopefully give me some advice on what to do.
Old 06-13-15, 12:10 PM
estomax
estomax's Avatar
You are talking about the mixer flap in the dash? The heater control valve is a vacuum solenoid in the engine bay on the pass side near the firewall that controls hot coolant going into heater core.
sailorpam
GS - 1st Gen (1993-1997)
02-14-14 07:04 PM
Gunnut
12-24-13 06:29 AM
lexluva
11-27-10 04:06 AM
BAD RIDES
05-17-08 08:23 PM
kensteele
05-31-06 06:22 PM
Quick Reply: A/C blowing cold out of pass vents, warm out of driver's vents.
