SC- 1st Gen (1992-2000)
On 92 SC300 which control arm ball joint (UppervorvLower) supports Spring.
Old 06-06-15, 02:21 PM
Alexusc300
Alexusc300's Avatar
Default On 92 SC300 which control arm ball joint (UppervorvLower) supports Spring.
On 92 SC300 which control arm ball joint (Upper or Lower) supports Spring.
Which ball joint is the load bearing ball joint.
I want to replace the control arm ball joint assembly on the front wheels but only the ones that are load bearing. Is it the upper or lower control arm? Which control Arm is the Spring on (Upper or Lower)?
Thx
Alexusc300
Old 06-06-15, 03:09 PM
eknine9
eknine9's Avatar
Lower Control Arm Ball Joint is Load Bearing.
Typically to replace the ball joints on these cars the entire arm needs to be replaced unless you plan on cutting one off and welding a new ball joint onto the old arm
CManolo
12-05-14 03:35 PM
BoostAddct
Suspension and Brakes
11-24-11 07:23 PM
Crazedshif
07-12-11 12:14 AM
i ride
13
04-27-11 05:09 PM
92blacktt
05-17-09 05:32 PM
Quick Reply: On 92 SC300 which control arm ball joint (UppervorvLower) supports Spring.
