obd1 scanner?
obd1 scanner?
Is there a scanner that i can use for our obd1's instead of using using the jumper method? If so do you guys know what brand and model that will work? I have rented one from oreilly that said it would fit Toyota and Lexus but turns out it didn't
If you have a serial port to usb adapter and a spare serial cable you can get live readings with an obd1 stream reader that some russian guy made. Im on mobile but ill find the link later if u cant.
Otherwise you can do the paperclip trick and there is a bulb output you can put a 12v bulb into with the dlc connector.
Why dont you pull the cluster and put the cel bulb back in?
Urvish
06-14-17 07:16 PM
