SC- 1st Gen (1992-2000)
Cleared Tail Lights with PIC's - #1
Old 03-31-03, 01:59 PM
wmulli
wmulli's Avatar
Default Re: great mod
Originally posted by The Ikon
And you made it so easy...
Thanks, but it really is easy! Anybody with some time and patience can do it The hardest part is baking the expensive tailights!
Old 03-31-03, 03:51 PM
LexFather
Guest
Posts: n/a
Sweet! Nice write-up!
Old 04-01-03, 09:15 PM
stelios
stelios's Avatar
That looks great
Old 07-09-03, 09:37 PM
smelkony
smelkony's Avatar
Default TRIED IT
I tried doing it but i cant take apart the inner lenses from the outer lenses. In the instructions it says there is a little screw that you have to unscrew to take it apart, but i cant find it. please email me at smelkony@aol.com or call me at 818-317-6707
Old 07-10-03, 05:01 AM
Keith13b
Keith13b's Avatar
Make sure you have the right year lights.
Old 07-10-03, 06:14 AM
bigdaddyrobb
bigdaddyrobb's Avatar
wmulli
Could I use one of the resistors to slow my blinking on my 92 with 95 tail lights? What ohm should I use? I have been looking for a solution to this for a while. It is something like this or rip apart a 92 turn signal flasher module and try and adapt a 95 turn signal flasher module to fit in it.
Thanks
Old 07-10-03, 09:11 AM
SC300TURBO
SC300TURBO's Avatar
i have an extra set of 92 tail lights in my garage is anyone wants em make me a good offer.......these would be perfect to clear out
and my car is still for sale also....
Jeff
Old 07-10-03, 09:38 AM
TurboSC
TurboSC's Avatar
Jeff, any suggestions on HOW to clear them out? They look like the plastic is dyed red/orange.
Old 07-10-03, 10:14 AM
LexusBiz
LexusBiz's Avatar
Oh Man, Oh Man another "To Do" action item
The list just keeps on growing.
Thanks for the great info.
LexusBiz
Old 07-10-03, 02:22 PM
SC400TT
SC400TT's Avatar
Great Mod!! Thanks for the info. Looks like a weekend project to be done soon!! Awesome looking!
Ryan
Old 07-10-03, 02:42 PM
wmulli
wmulli's Avatar
Originally posted by bigdaddyrobb
wmulli
Thanks
Hey Robb,
I wish I could give you an answer, but I really don't know about '92's. The reason I needed the resistor was because the resistance of the LED's I put in was much less then the stock bulbs, hence adding the resistance cured the problem of the fast flashing. Since I don't know what's causing your fast flashing, I really don't know what to tell you. You could certainly try the resistors. They're relatively cheap and I can't see that it would hurt anything. Worst case would be you'd have a couple of resistors that didn't do what you wanted
The resistors I used were massive 50 watt, 6 ohm jobs. I think these are overkill since the turn lights are only on intermittantly. You could buy some cheaper 6 ohm, 5 watt resistors from Radio shack to try and see if they slowed your blink rate. Just wire them across the rear turn signals. Make sure you check to see how hot they get. If they get too hot, you'll need the heavier resistors.
Good luck and let us know how it goes!
-Walter
Old 07-11-03, 04:52 AM
Keith13b
Keith13b's Avatar
Jeff
You can't clear out the first gen tail lights!
Old 07-11-03, 05:36 AM
bigdaddyrobb
Thank Walter. I think I will give it a try. The trun signal flasher module swap would be really time conuming plue I would have to figure out the wireing myself. I'll let you know how it turns out.
Old 07-12-03, 06:55 PM
adidosc
adidosc's Avatar
nice job! for me...i will be happy just buying the 97-00 tail lights and putting them in.
Old 09-29-03, 10:26 AM
LexusBiz
LexusBiz's Avatar
Hey Walter,
I finally got the 95-96 taillights on my 92.
Question for you regarding the resistor install to slow down the blinkers. Did you install 1 resistor per taillight or just one resistor total? Also where did you wire the resistor into? Did you wire it into the single pair wire going to the turn signal bulb socket?
I am assuming I will need to splice one of the single wires going to the turn signal bulb socket and install the resistor.
Any assistance is greatly appreciated.
Thanks
LexusBiz
Quick Reply: Cleared Tail Lights with PIC's - #1
