SC- 1st Gen (1992-2000)
Cleared Tail Lights with PIC's - #1
Old 09-29-03, 11:15 AM
  #31
Richie
Richie's Avatar
What an improvement!!
Old 01-24-04, 11:32 AM
  #32
TrboDANDEE
TrboDANDEE's Avatar
could you do this on a 93 and 97+ tail lights?
oh ya, bump for the LED pics
Old 01-25-04, 12:18 AM
  #33
djsoarer
djsoarer's Avatar
Default TrboDANDEE
you cannot do this to the 92- 94 tailights but if you like that style better than you can buy these from www.takakira.co.jp but they are like $800 + shipping
Attached Thumbnails Cleared Tail Lights with PIC's - #1-active_k-img600x277-1065745175301.jpg
Old 01-25-04, 12:20 AM
  #34
djsoarer
djsoarer's Avatar
i'm not sure about the 97 + tailights but i was thinkin about pullin them apart like your gonna clear them for the 95-96 but instead of doin that just paint the orange part red.
Old 10-22-09, 03:50 AM
  #35
94LEXUS400
94LEXUS400's Avatar
Default Cleared Tails
I am wondering what if I remove the diffuser @ the bottom for 95-96 tails...
Would it be legal? I saw Evergreen(?) tails which had them all removed...
I really like the clean look without diffuser..
Thanks in advance for your opinions.
Steve
Old 10-22-09, 08:08 AM
  #36
ishootstuf
ishootstuf's Avatar
Sweet. A 6 year old thread revived!
Old 10-22-09, 08:14 AM
  #37
Schultino
Schultino's Avatar
I'm doing this
Old 10-22-09, 03:42 PM
  #38
soulific
soulific's Avatar
anyone ever try paint the hosuing inside directly behind the clear section black? Kinda like black housing headlights to black housing or give a smoke look to the clears?
Old 10-23-09, 12:41 AM
  #39
94LEXUS400
94LEXUS400's Avatar
I wonder if these have good light output without diffuser....
It just seems like they removed the inside of 95 tails..
I dont want dots of light...Wondering if these would look ricey...
Old 11-02-09, 11:52 AM
  #40
96SC4
96SC4's Avatar
where would i buy this clear diffuser(in post #1).....? Is this something i would find in Home Depot?
Old 11-02-09, 12:22 PM
  #41
wmulli
wmulli's Avatar
Wow! Talk about your blast from the past!! LOL!!
I bought a sheet of plexiglas that's used in flourescent lighting fixtures. It comes in 2 x 4 foot sheets, and it's only a couple of dollars. I got mine at Home Depot, but Lowe's or any hardware store should have them.
Good luck!
Old 11-02-09, 12:24 PM
  #42
96SC4
96SC4's Avatar
wow! wasn't expecting OP to respond to this one....being so old! lol.
thanks for the quick response!!!
Old 11-02-09, 12:28 PM
  #43
wmulli
wmulli's Avatar
Originally Posted by 96sc4
wow! Wasn't expecting op to respond to this one....being so old! Lol.
Thanks for the quick response!!!
who you callin' old??? Roflmao!!
  #44
Lexiss_sc430
Lexiss_sc430's Avatar
Originally Posted by 94LEXUS400
haha that's my SC, I was one of the first people to do this mod.
Old 07-21-10, 05:23 AM
  #45
High PSI
High PSI's Avatar
Originally Posted by wmulli
Hey Dan,
Sorry I wasn't clear. I'll try again.
There are LED's available as direct replacement plugins for the standard incandescent bulbs. In the case of the '96 SC, the rear brake lights, turn signal, and backup light are all 1156 (bayonet base with single filament). The rear "driving lights" and side marker lights are 194 (wedge base). The front turn signal is an 1157 (bayonet base with two filaments) for reasons unknown since, the SC only uses one filament in it?!? The 1156 and 1157 are not interchangeable as the base is different.
There are lots of places on the web (and even eBay) to get LED's, but the quality and output of light varies considerably from brand to brand. I can recommend the place where I got mine as being reputable and having good quality bulbs (as well as the resistors - more on them in a minute), as well as fast shipping. Check out DirectAuto.com (NOTE to Moderator - I'm not affiliated with this company, just passing along info about what I consider to be a reliable merchant!). They carry all the types and colors of LED's for auto use, 1156, 1157, 194, etc., etc., etc. They also carry the resistors you need to make the blinkers work properly.
The problem with using LED's is they have a VERY low resistance. This confuses the blinker and the circuit that senses when a bulb burns out. For the blinker, merely wiring one of these 6 ohm resistors ACROSS (one side to +, the other side to -) the blinker LED will take care of it. I expect this would fix the bulb out sensing circuit for the tail lights as well, but have not tried it yet. What I'll probably do is just unplug the light bulb in the dash. The LED's will probably outlast the car anyway
One last note. Don't buy the 1156 or 1157 with less than 15 LED's or they won't be bright enough. And for the 194's, get the 4 LED bulbs, NOT the two LED ones. If this is confusing, check out the web sight and it should all become obvious.
Hope this helps!
PS- Still don't have pics yet, but hopefully soon!
Lots of good info in this post...but I'm bumping this from the dead again!
Question about the bulbs - what is the total count of bulbs in the 95-96 tail-light? It looks to me like EACH tail light has the following:
(2) 1156 - Red in the top of the tail-light. Bright when braking, and lightly illuminated when the lights are on.
(1) 194 - Red in the top of the tail-light - lightly illuminated when the lights are on, but does nothing different under braking. "Rear Driving Light"
(2) 1156 - Amber for turning
(1) 1156 - White for reverse
Yay? Nay? Ordering LED's for my tails, but at ~$20 a bulb I want to make sure I'm ordering the right stuff. I don't have time to pull my tail-light to check before ordering the bulbs.
EDIT - Looks like I'm a bit off...
Quick Reply: Cleared Tail Lights with PIC's - #1
