Window regulator and build date on a 93 sc400
I've read and searched everything I can, but have a couple of questions.
My right window plastic crappy thing broke, I have it out. The 2 bolts at the top are 8.5 cm apart. Is this the early or late model and where is the data plate so I can tell the month of build?
My drivers side works but the window stops about 1/4" from going up all the way, and I saw that this may be from someone installing the wrong regulator-but if the bolts mentioned above are seperated a different dimension it should not fit the factory holes. Correct? Because I don't see ant way to adjust the travel.
Also is there a guide to install new door hinges? The P.O. gave me some for the drivers door-it just looks like a royal PIA.
Note: to anyone hesitant to put new transmission mount in-just do it. BEST $60 you'll ever spend on this car. Don't know why I waited so long........
