P/S reservoir puking fluid
My SC4 has had a low moaning sound since I got it and when I started it up today it was a little louder than normal so I pulled the cap, with the car running, and it puked fluid out. When I turned the car off and checked the reservoir was dry. Filled it and it went back to a low moaning sound.
The fluid didn't appear to be super foamy so my questions are
low moan with no visible leaks, live with till it dies? replace the pump? or after some reading I've seen where there are some seals that can be replaced. Please educate me on this.
Also someone please explain exactly how to properly phrase my search words so I can get decent search results. When I searched "power steering" I got a butt ton of threads.
Thanks
Greg G
Thanks
Greg G
What I did was try to imagine every way someone may word the issue and search for them all. I had a similar issue. Here is one of my threads as a starting place. I have to try and remember what piece they replaced that worked.
https://www.clublexus.com/forums/per...ain-extra.html
