Crank Shaft Pulley bolt removal tool bolts
Does any one know the size of the Crank Shaft Pulley bolt removal tool bolts?? Confusing I know but the screws that go in the removal tool I need to buy some longer ones Im creating my own tool..
Autozone has the pulley removal tool for $20 plus tax, (rent it, return it, and it's free via there loaner tool program) then find the two bolts that fit your pulley and take them to a hardware store. I would get "Grade 8" bolts if I were you, last thing you want is a cheap bolt snapping in there. I am actually having to do the same thing in order to torque the crankshaft bolt to 181lbs. From what I saw on youtube a 2x4 will do the job just fine as long as your bolt holes are drilled nice and tight with little to no play.
What tool exactly? I went there recently and I couldn't find one to take off the Pulley bolt. I have rented their harmonic balancer already but before I do that I need to get the bolt off. Thanks for the response btw
I used breaker bar and took the handle from my floor jack and slipped it off the handle and used that.....I wedged a pry bar on fly wheel to keep it from spinning...
The best bet is an impact wrench.....i.e air tools.....but I was able to do mine with the above mentioned...
In order to get the bolt off I bumped the starter, basically put your breaker bar/socket on the crankshaft bolt and wedge it somewhere(I used the battery area, then hooked the battery back up quick and tried to start the car. One crank(about 2 seconds) broke the bolt free.
Im changing the head gasket so I'm too far along in the process to do the starter bump method. Also are you guys saying I could use the harmonic balancer puller to get the crankshaft bolt off? Because its just the bolt that I have to get off right now.
