There is a connector with 2 wires both the socket and connector is mounted on the housing so just trace the wire to the socket and turn counter clock wise
The battery side is kind of a pain but doable unless your hand is too big
^^what he said, the battery side really sucks. I had to slide the battery out of the way. I just unplugged both sides but I plan to match the HID as well. I'm In for pictures.
The small secondary bulb is a 168/194 push in. 2 wires go into a plastic socket which has a flat tab at the back. if you can get a good grip on it with 2 fingers rotate it clockwise or counterclockwise till you feel it release then pull it straight out. There are 4 little tabs on it that go into 4 slots on the mount. Battery side is harder to access and may require you move the battery.
