SC- 1st Gen (1992-2000)
Led turn signal blinks fast
Old 09-19-15, 08:21 PM
Lveyolfe
Lveyolfe's Avatar
Default Led turn signal blinks fast
I ordered some white leds turn signals, installed them and now they blink fast as if one is burnt out. But when I turn the hazards on they blink normally. Solutions to this issue? Thanks!
Old 09-19-15, 09:11 PM
t2d2
t2d2's Avatar
From what I gathered in my own tests, the hazards are not part of the "bulb out" circuitry that results in the hyperblink. The turn signals, on the other hand, will hyperblink if the voltage (or is it resistance?) is outside the range it expects, as would be the case with a blown bulb. LEDs are known to trigger that scenario.
Others will have to chime in on established solutions such as correct LED values or resistors to fake the load.
Old 09-20-15, 10:33 AM
GISguy
GISguy's Avatar
Amazon.com: 50W 6Ohm LED Load Resistors for LED Turn Signal Lights or LED License Plate Lights (Fix Hyper Flash, Warning Cancellor): Automotive Amazon.com: 50W 6Ohm LED Load Resistors for LED Turn Signal Lights or LED License Plate Lights (Fix Hyper Flash, Warning Cancellor): Automotive
Splice one of these in to the positive and negative wires going to the LED. It'll solve your issue.
Old 09-20-15, 12:25 PM
kolessc400
kolessc400's Avatar
You will need a risistor installed in the wire. The led is a lower resistance than stock bulb. So you will need to test resistance on stock bulb then measure on led then get a resistor that is the diffrence between the resistance and install it
Old 09-20-15, 01:45 PM
OG Dada
OG Dada's Avatar
It depends what year your SC is, so far I have tried in a 95 and 96 SC swapping the flasher relay to a direct replacement digital flasher relay. The 92-94 SC's have had no luck with it though. If you wanna try it click on my SC400 daily driver build in my sig to see the kind of relay I used. That'll be much cheaper, easier and cleaner mod than splicing a load resistor on each bulb.
Old 09-20-15, 02:29 PM
kolessc400
kolessc400's Avatar
Either way would work up to youlater how to go about it but he is right easyer yes cheaper not so sure
Old 09-20-15, 02:36 PM
Lveyolfe
Lveyolfe's Avatar
If I bought those cables, what is splicing it into the bulb? Sorry I'm not familiar with this stuff
Old 09-20-15, 03:17 PM
kolessc400
kolessc400's Avatar
Cut the wire to the bulb and place a resistor in the cut area and tape it up
Old 09-21-15, 03:22 AM
GISguy
GISguy's Avatar
This.
Old 11-27-19, 08:02 AM
Chito95
Chito95's Avatar
Default Hey
I'm having the same trouble but mine aren't led I have aftermarket taillights that only have 4 bulbs and my old one had 6 so im having trouble with the blinker
Old 11-27-19, 08:35 AM
mrmj2u
mrmj2u's Avatar
This is the best way to fix the hyper blink issue: https://www.clublexus.com/forums/sc-...led-tails.html
Grisik
07-18-21 03:02 PM
NjDude
RC - 1st Gen (2015-present)
18
08-06-15 11:10 AM
VtotheJ
IS F (2008-2014)
13
11-14-12 09:42 AM
George94
05-20-03 05:01 PM
Quick Reply: Led turn signal blinks fast
