A/C condenser.
I don't see why not? Take it to you local welding shop or an AC shop and explain to them what you need done. I had my AC hoses rebuilt by cutting and welding. The fee should be minimal.
did you try www.car-parts.com ?
thats where I got mine for 150. and it works great. might be worth a try.
Keeper of the light
there are driers cheap on the bay right now if you dont have one yet. 39 bucks. you'll be replacing that also, just thought i'd let you know where you can strike a deal right now while they are running cheap.
onelasttry: dryer? what is that used for?/
you bulbs are awesome by the way.
Keeper of the light
if you open the a/c system up and discharge it you have to replace the reciever/drier. i am unsure of the pep boys quality, but the one's i've seen on the bay are very good quality. (glad you like the bulbs).
Originally posted by VSsc400
thanks man. just got one for $110shipped with 6 months warranty!
glad you found something.
The filter/dryer or receiver/dryer is a canister full of silica gel crystals that will absorb small amounts of moisture in the system. It's basically the same stuff that comes in the packets marked "do not eat" (duh!) that come packed with new cameras, electronics, etc. Water is the enemy of a/c, if it is present in even tiny amounts it will cause icing of the expansion valve (or cap tube, depending on the type of system) and the ice will plug up the system and it won't work. If the system has been out of service for a while, ambient moisture will invade the system and the silica gel will saturate, that's why you need to replace the dryer. When you get the condenser replaced and are ready for a recharge, be sure to have the system purged with nitrogen before a vacuum is pulled and it is charged - the purging will drive out most of the moisture, and the new dryer will take care of what's left.
