Driftmotion 1jzgte single manifold owners chime in - oil return discussion
Lets have a discussion, also maybe this thread will serve as a good information when choosing manifolds
I have had this manifold for a good minute now maybe less than a year. The only way to fit a return in this manifold is using a 90 degree -10 an fitting. Did not even think about it till recently my super reliable 4 year old precision turbo started getting shalf play.
Anyone else who had this manifold do anything to put say a 45 degree fitting in? Was thinking a t4 spacer may do the trick
This is not to put driftmotion on blast but I'm severely disappointed after hearing good things about this kit
I found a solution to this that will work getting a 45 degree fitting in there, and this is probably the best you can do I don't see a 30 degree being possible
Here is a close up of the 90 degree fitting there is no fitting anything, pretty poorly designed manifold but I can work with it. I did call driftmotion and their response was we have sold hundreds of these manifolds and no one really has had a problem
![](https://scontent-atl3-1.xx.fbcdn.net/hphotos-xpt1/v/t1.0-9/12112118_10153820599427259_6820262139162987919_n.jpg?oh=d6739b3f7e67d2be53094f26f9e653f5&oe=56923B5A)
So I went and got a 1/2 T4 spacer from my friend Matt at JEI and got some different length and size 45 degree -10 an fittings from another friend. The spacer only cost me $25 and the fittings were free
![](https://scontent-atl3-1.xx.fbcdn.net/hphotos-xpl1/v/t1.0-9/12063429_10153820599752259_3931629799035780921_n.jpg?oh=101c6ac9e0dc50d633376bedc0af180d&oe=5690638F)
Using the shortest 45 degree fitting and the spacer and clocking the middle of the turbo about 10-15 degrees I was able to fit the 45 fitting.
Here is some pics of the 90 degree fitting - as you can see the runner is in the way no possible way of getting a straight fitting there
![](https://scontent-atl3-1.xx.fbcdn.net/hphotos-xtl1/v/t1.0-9/12096157_10153820599502259_7723394447122169591_n.jpg?oh=b550bf6c03fec7ea665ad9a808238d00&oe=569B7A93)
Here it is with the 45 degree fitting and spacer - haven't bolted the turbo on fully yet
![](https://scontent-atl3-1.xx.fbcdn.net/hphotos-xta1/v/t1.0-9/12106869_10153820599572259_2197211229965979765_n.jpg?oh=019750230b3b8e8aabf126f0f165ba3a&oe=568F7C62)
Kind of hard to see but here is the turbo senter clocked about 10-15 degree - please correct me if you think this is more than 15 degrees kind of hard to tell. From what I read 15 degrees is about as much you can safety clock it
![](https://scontent-atl3-1.xx.fbcdn.net/hphotos-xat1/v/t1.0-9/12118702_10153820599637259_2867802699944693351_n.jpg?oh=c85e052b7e386b3bc0923010b2a1439e&oe=56C63C81)
