SC- 1st Gen (1992-2000)
Driver seat switch question/issue?
Old 10-13-15, 12:19 PM
jlamonica
jlamonica's Avatar
Default Driver seat switch question/issue?
I recently picked up a 1993 SC300. LOVE the car. It needs some interior TLC, but I'm up for it. Already fixed interior and exterior passenger door handles and replaced the window regulator on that side.
But I have a question about the functioning of the driver seat switch. The long horizontal switch's rear-most function does nothing (see photo). I feel like I'm sitting a little high and would like to lower the seat height. The rear position of the seat bottom adjustment does nothing when pushed up or down. The front part of the switch adjust the angle of the seat bottom to control the height of the front of the seat. What should happen with the circled part of the switch? And, if I have a malfunction, what do you suggest?
Old 10-13-15, 12:20 PM
jlamonica
jlamonica's Avatar
Forgot the photo. Oops. Noob.
Old 10-13-15, 12:32 PM
freakness
freakness's Avatar
Dude,
I suggest a 50/50 mix of Simple Green and water. Filthy seat is filthy.
- good luck
Old 10-13-15, 12:35 PM
jlamonica
jlamonica's Avatar
I told you it needed some interior TLC. Working through it as time allows.
Old 10-13-15, 01:32 PM
Ali SC3
Ali SC3's Avatar
mine doesn't work either, have been too lazy to investigate. definitely not the dirt mine are clean.
Old 10-13-15, 07:46 PM
t2d2
t2d2's Avatar
My passenger seat recline/tilt didn't work. After tearing everything apart and determining that the motor was fine, I eventually figured out that the plastic rocker switch on the controls was melted on one side and not making contact.
Old 10-16-15, 08:08 AM
jlamonica
jlamonica's Avatar
Did you have to remove/replace the switch? If so, what did it take to accomplish? I'm assuming you provided 12v power to the motor to test it? Anybody else ever had to remove/replace/repair that switch?
Old 10-16-15, 08:42 AM
t2d2
t2d2's Avatar
https://www.clublexus.com/forums/sc-...ml#post8677041
The control switch unplugs and isn't terribly expensive to replace. I think my pass. one was $25. I remember using 9V battery power to test the motors, but I tried that again not too long ago and it wasn't working, so maybe I used 12V. I haven't seen anyone else report that issue with the switch.
Old 10-16-15, 10:16 AM
jlamonica
jlamonica's Avatar
Thank you, t2d2.
gs4bkny
09-25-12 06:35 AM
dbs600
04-28-12 04:50 PM
ldfog
12-03-09 11:20 AM
shajbot
02-02-09 05:57 PM
edscuba
RX - 1st Gen (1999-2003)
11-19-03 11:11 AM
Quick Reply: Driver seat switch question/issue?
