So, I just brought this home...
#31
Honestly, I'm not sure what's up with them. At first, they weren't working and cleaning the contacts at the plug/back of switch got them working again. Just checked again today and they are not working again. Are the modules ever intermittent? I was under the assumption that the modules are either good or bad.
RXRodger, I appreciate the offer. If it comes down to needing a module, I'll shoot you a PM. By the way, have any interior parts you're not needing?
Let me know if you find it to be the module bad, I may have one. I just stripped out one SC and won't need that module since it is now a full race set up. But, come to think of it I might need to keep it for the other SC I have. But if you really need one I would probably part with it.
#32
Is your memory seat function working? I remember reading something about the power memory seat ecu locking up if some part of the memory system ( seats, mirrors, steering column, ) isn't moving properly, then you have to unplug the memory buttons for it to reset...wonder if this is the case with your mirrors...
Anyway, If rxrodger doesn't want to part with the module, I think I have one in good working order I would be willing to let go. I also have a lot of grey interior parts laying around...
Let me know. Alan
Let me know. Alan
#33
Hey, Alan. At this point, I'm not 100% sure. The seat memory seems to work fine but, since I'm the only one driving it I don't use it much. The few times I've tested it seemed fine.
The steering wheel memory is hit or miss. It sometimes works, others it doesn't. With that said, it always tries to come back to where I left it when I get in the car and sometimes it completes the motion and other times it stops about half way. Whenever it stops mid way, if I try to move it manually, it doesn't work. Then, a little while later I am able to move it again. I haven't looked into that yet as it's not very high on the things that bug me right now. I know there's some DIYs on the steering column motor fixes.
I'll have to contact you about the interior parts.
