Does an aristo diff fit in a soarer?
i have a 93 aristo torsen diff i want to install in my 91 soarer. does it fit or can i even transplant it into the soarer pumpkin? anyone knows this?
^^^^ Yes. The only thing that should require changing is the companion flange (to connect to the rear driveshaft) which may be different between the Aristo and Soarer. Be advised that you can take the diff to a driveline shop to have this done or do it yourself with the Toyota Supra or Lexus SC factory service manual but the procedure needs to be followed exactly. And it requires a dial-torque wrench, not a more common click-threshold torque wrench. Not overly hard but has to be done right.
Other than that... it's bolt in on a Soarer (or SC)
