SC- 1st Gen (1992-2000)
FM antenna routing
Old 02-23-16, 08:47 PM
Deathbarel
Deathbarel's Avatar
Default FM antenna routing
where does the fm antenna route through the car it open between the power antenna and the radio wire
Old 02-24-16, 11:42 AM
BiGEZ
BiGEZ's Avatar
The oem antenna cable run from behind the radio up the passenger side A pillar across the roof lining and down the driver side rear qtr. panel to the trunk. Think there is a connection to a second antenna built into the rear glass at the top where the headliner is. If you pull down on the headliner along the rear glass in the middle you should see the cable.
I would suggest just running a new cable from the radio along the frame rail to the trunk.
cep89
GX - 1st Gen (2004-2009)
10-16-21 07:34 AM
Blaze420
02-16-19 04:25 PM
jr4div2
12-18-17 11:49 AM
Aron9000
04-26-16 12:05 AM
boxcarfan
GS - 1st Gen (1993-1997)
08-19-10 09:51 AM
Quick Reply: FM antenna routing
