2jzgte aristo swap mount bracket clarification
I've seen the threads regarding this topic but there is a bunch of jibber jabber about who's right and who's wrong, worse than the Trump debates, no straight answers. So someone please tell me if my 94 tt supra mounts will work with the supra engine mount bracket 1231146041 and 1231546041?? I'm swapping an aristo into a sc400. Spare me the I should of gone with an sc300, I picked this car up for 700.00 and it's super clean. Thank you for any help.
Ok thanks guys. I had to grind of the alignment pin for the mounts to fit in the brackets, is that normal? I live by induction performance and they were the ones who advised me on this setup. I also have done the supra oil pan conversion. Next is ac delete kit from drift motion. I've already done a 77mm single turbo swap, new intake, 80mm throttle body and 750 top feed e85 injectors along with walbro 450 e85 pump. This is going to be a race setup car so any other input on what systems or sensors can be deleted would be great! Thanks again guys
You shouldn't need to grind the pins down at all.
Check out this thread https://www.clublexus.com/forums/sc-...or-mounts.html
Second post has a picture of the correct mounts and brackets.
The all metal mounts are from a 93-96 supra.
The bracket part #s you listed are from a SC/97-98 Supra.
Cleanshots
Performance & Maintenance
07-05-08 06:33 PM
