Passenger Window making screeching noise?
When I roll the Passenger widow down I hear this awful screeching noise but I don't hear it when I put the window up. Has anyone else had this issue? Sounds like it needs some grease or the track needs to be adjusted/? But it goes up and down fine,?
I did this last week with mine. I grabbed a bottle of spray silicone at Autozone and sprayed it inside the window track and rubber trim using the tiny straw it came with. Just let it sit for a minute or so to soak in and wipe off the runs and drips. Roll the window up and down a few times and even spray while its going up and down to kind of push it in the grooves. It'll be silent and roll up/down faster when you're done.
gs3andahaf
03-16-13 10:29 AM
