How does everyone go about rolling fenders
I seriously want to know how everyone rolls and pulls their fenders. I know you can take it to a shop but that can be costly? anyone do it themselves ? Lmk about it if you did I'm very curious on the topic.
The "proper" method is getting a fender roller (buy or some places rent). You carefully use a heat gun to heat up the area to prevent the paint from cracking, but not so ht to burn it. Then slowly roll flatter and flatter. Probably 20-30 minutes per corner.
Others heat it up and roll with a baseball bat. I've seen heating it up, jacking up the car, putting a phone book in the gap and lowering the car which would also pull the fender out a little.
I think all of the answers above is about it my man. One member said he used pliers and his hands... Another said he saw(just as good as doing) it done by another method...
Good luck and post pix
My son and I bought a cheap wooden bat and a $15 heat gun from harbor freight and jacked the car up and slowly rolled it. There are alot of videos on youtube you can check out. The only problem we had was on the drivers front side the fender moved a little and we had to readjust so the door would open and close. If I were going to do it again I would probably put something in the door crack to keep this from happening again.
6chuchu6
IS - 1st Gen (2001-2005)
16
03-18-13 01:06 AM
