tell me im not crazy CL
Thank you for your business and the recommendation! We will always take extra great care of our ClubLexus friends!
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
262-456-4147
it doesn't look to bad I would think you can clean most of that off and the traces would be fine so Tanin should probably be able to do it, but you can see why you are having problems. that other guy is just being extra cautious but a little cleaning will probably go a long way here.
You are correct in that one of the signs of a faulty ecu is the check engine light not operating on key on for a second. Sometimes people pull the check engine light bulb out of the cluster though so only if the bulb is in and you know it used to work does that tell you there is some issue with the ecu.
Not at the moment, but let us see what we can do for you! Email our marketing manager at taninautomarket@gmail.com with your contact info and we will be in touch with more info on stickers!
Thanks again,
Thanks again,
__________________
262-456-4147
262-456-4147
just a quick update , I got the ECU back from tanin yesterday and everything is good to go! I even got my OD back which is just awesome . Thanks to Tanin and everyone who helped me. It gets discouraging after 2 months of chasing codes and not being able to drive my baby.. on a side note i managed to get a trunk with oem spoiler for $50 and two almost perfect front seats,driver door panel,armrest and headlights for only $100. So my interior is darn near flawless now.
__________________
262-456-4147
262-456-4147
