Fuel Relay or Ignition Switch?
I've got a '96 sc300. Sometimes I get in to crank the car & it won't start. I put the key in & turn the switch; lights come on, radio comes on but it won't turn over at all. The first couple times it does nothing, but around the 2nd or 3rd time it will click but still no fire. It doesn't even attempt to turn over. I keep trying & it eventually fires up. It only does this sporadically. I can go days without any problems, then some days every time I try to start it up it'll do it. Sometimes it might crank on the 2nd try, sometimes it may take several tries (or 45 minutes) to get it to start. Sometimes it will try to turn over but die before the engine starts. I was thinking it may be the ignition switch or maybe even the starter but I called a mechanic friend yesterday (while stranded) and described the issue with him. He suggested it may be the fuel pump relay & said it's possible to bypass the relay. Any suggestions would be great!
Dude,
What error codes are you seeing, if any?
Also check your PRND switch or position of the shifter ... needs to be pushed all the way to Park. Next time it fails to crank (no click or anything) jiggle the shift lever or try starting in "N" (will need to realease it).
If you hear click(s) then it is your starter solenoid.
Salim
Salim
