SC- 1st Gen (1992-2000)
Wiring Harness Repair Questions
Old 04-20-16, 05:46 AM
deputy865
deputy865's Avatar
Default Wiring Harness Repair Questions
I'm in the middle of my build now and I need to start focusing on my engine wiring harness. My end goal is to tuck and hide it away.
However...
My harness is worse than I thought. Now, I've never done this before, but I trust my ability to get it done correctly. What I'm asking is how I should go about fixing it!?
My intentions were to locate each and every plug I have and label it at both ends of the wire. Once I've done that, I would clip the plug off, add it to the new wire and remove the old one completely. Do that x100 for every plug/wire until I'm only left with the plugs I need (I removed deleted some stuff). I would probably add ECU pins to the wire ends, but not plug them into the ECU until I have everything plugged in and the car wired up... That way when I go to tuck, It in theory should be easier to extend the wires and get them where I need to be, all while hidden.
Thoughts? I feel like I'm making it sound too easy.
Pictured below is how the previous owner(s) extended my harness. After said extensions, my wires are all tangled, crossed, messy, etc.
Old 04-22-16, 05:18 AM
deputy865
deputy865's Avatar
No one?
Was hoping to tackle it all this weekend.
Old 04-22-16, 09:06 AM
gerrb
Super Moderator
gerrb's Avatar
are those wires only taped or shrinked wrapped also ?
Old 04-22-16, 09:49 AM
deputy865
deputy865's Avatar
Sadly, only taped... Gotta love previous owners
Old 04-22-16, 10:00 AM
gerrb
Super Moderator
gerrb's Avatar
dang... that's what you got to do then .. make sure they are all shrinked wrapped
xspsi6
SC400 / 300 Classifieds
06-14-13 07:09 AM
TLDriver
Performance & Maintenance
09-27-09 02:42 AM
page2two
03-31-08 12:05 PM
Quick Reply: Wiring Harness Repair Questions
