6sp tt pumpkin into sc300
Please help looking to swap 350z tranny into my car .
want to change out my rear diff from supra 6 speed for lower my gear ratio .
my question is can I direct swap supra 6 speed tt pumpkin into my sc300 with out modification
I search but everybody use auto tt pumpkin
thank you all
thank you all
6speed diff doesn't fit without the supra subframe. you can get just the TT torsen diff and throw a 3.26 gear on it from either an SC430, GS430 or 98+ SC400. otherwise the stock auto TT pumpkin has a 3.76 gear i think.
are you sure about that? i've never heard of it fitting... we're talking about the V160 diff right, the one that also needs the driver side TT axle as well?
I found a really good deal on the 6spd diff and i needed so should i get it if it not fit i cant return it .
I push 750whp on my stock w58 and rear diff my tranny is broken last night .
im buying it from supraforum he located in canada and his car is right hand dive so it not usdm diff .
can i still use it if it from jmd 6spd
