You have to take off the headliner and then it exposes the whole unit
Uh, no. That's a ton of extra work and will most likely do irreparable damage to the headliner. The OP asked about the glass, not the entire assembly.
Just unclip the two side plastic trim covers on the bottom of the glass and they expose a 10mm bolt at each corner. Remove those and the glass lifts out.
