SC- 1st Gen (1992-2000)
sc300 transmission issues
Old 09-09-16, 02:41 PM
96wickedsc
96wickedsc's Avatar
Default sc300 transmission issues
hello,
i have a 96 lexus sc300 and about a month ago i lost reverse and neutral turned into a drive gear so i put it into a shop and had another used transmission put in.and now a month later i have having the same issue reverse seems like its in park and neutral is in drive.someone please help me i spend 900 get work done to the transmision and now its doing the same thing.i hope someone out there knows transmissions and can tell me what the problem is.because i am really tired of sinking money into the car and in the end having the same issue.
Old 09-11-16, 10:37 AM
CDD200
CDD200's Avatar
Sounds like a shifter linkage or valve body issue. Call 2-3 auto trains shop and talk to them about it. If I paid 900 for a repair I would go back to the shop that did the work and talk to them too. I know a few shops down here is savannah
Old 09-12-16, 06:59 AM
pishta
pishta's Avatar
sounds like a linkage issue if the gears are "one off"? Does park still lock the wheels?
Old 09-12-16, 12:06 PM
oSUPRAo
oSUPRAo's Avatar
I've heard that a bad ecu can cause all kinds of problems. I'm not sure if it could interfere with the transmission though. Hopefully more knowledgeable people can help and confirm/deny that.
Old 09-13-16, 07:15 PM
BlackIRON
BlackIRON's Avatar
Check your ECU.
Wafftho
06-13-22 12:12 PM
Donita
03-22-18 03:43 AM
Behemoth7
05-31-14 05:34 PM
1FSTV8
Performance & Maintenance
20
03-01-14 09:28 PM
ajmccarrel
04-21-12 01:37 PM
Quick Reply: sc300 transmission issues
