SC400 Pioneer Radio - Pass speaker issue
Hi, hoping someone here has experienced a similar problem. My 92 passenger side front speakers do not work. I have tried replacing the speaker and the head unit and that side still does not work. Curious if I should try replacing the amp? I'm wondering could some component not working correctly actually cause only one speaker to not work? Worse cause I assume is I have an electrical gremlin or broken wire somewhere. I like the OEM system and would just like to get the sound even. Thank you for the help and suggestions.
i've got the same problem on my '97 SC300, adjusted AV settings on my double din (also pioneer) to no avail. you ever find out the problem OP?
AlliexWond
SC- 1st Gen (1992-2000)
08-29-16 04:51 AM
horton
12-04-07 09:27 AM
jonathancl
08-31-06 09:39 AM
Dbl400Trbl
03-02-05 12:34 AM
