Could a 1997 Lexus 5 spoke rims fit a 93 sc300
...... and the offsets will be proper for your car....
Well it depends on which model lexus you are talking about. An ES300 wheel will not fit an SC300. But I believe the bolt pattern is the same for any 1992-2000 Lexus SC, 1990-2006 Lexus LS, and any 1993-2005 Lexus GS.
^ I stand corrected good sir![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
I thought since the ES is FWD/Camry platform, they had a different bolt pattern and offset. I think those six spoke ES wheels are great, different and funky, great looking factory wheel. Much better than the crap 15" "turbine" wheels my SC300 came with.
Also I have a problem with the sc300 it won't turn on crank at all when key is turn nothing happen nothing is lit only the door icon when door is open I bought a new battery fuel pump same problem headlight turns on when I switch it on but car won't start any solution ?
hey my sc300 cluster speedo and rpm needle aren't functioning it stay at zero wha could be the problem
