SC- 1st Gen (1992-2000)
1992 SC400 Rim Size options
Old 05-21-03, 03:40 PM
marcman18
marcman18's Avatar
Default 1992 SC400 Rim Size options
Does anyone know what sizes the Lexus SC can take. I want to get 18s,19s, or 20s. What is the offset for each size, does it take 17X7 ? 18X8.5 etc.?? Thanks
Old 05-21-03, 04:37 PM
Lex Luthor
Lex Luthor's Avatar
Call me @ work and i'll help you out, PM me for the number...
Old 05-21-03, 07:38 PM
marcman18
marcman18's Avatar
Default BREYTON 19s
Thanks but I just have one specific question. I want Breyton Ispiration 19s. I know that they are made for BMWs but I have seen them fitted to lexus. Will these fit on a 1992 SC400? They are size 19 x 9 with a bolt circle of 5-120mm with a +48mm offset or a 6.89" backspace. ANYONE PLEASE ADVISE ON HOW TO GET BREYTON WORK ON LEXUS. I am going to have these chromed too, they are going to look great.
CONTACT ME ASAP.
Old 05-22-03, 10:26 AM
Lex Luthor
Lex Luthor's Avatar
The SC is 5x114.3 marcman...
Old 05-22-03, 11:15 AM
marcman18
marcman18's Avatar
This is what Breyton sent me. Which adapter do I need and where can I find it. Which set should I buy. Thanks
below you will find the sizes and offsets available, please contact you lexus garage. they will inform you which
adapters are necessary. the lug pattern of our wheels is 5 x 120, the hube is 72.6 resp. 74.1.
9.0 x 19 offset 20
9.0 x 19 offset 38
9.0 x 19 offset 44
10.0 x 19 offset 16
10.0 x 19 offset 42
Old 05-22-03, 02:58 PM
dubbsc
dubbsc's Avatar
Default WHEEL SIZE
I have a 1992 sc400 I've a 16's-20's and I like the 19x9.5 best.but you can fit 20x8.5
Old 05-22-03, 05:52 PM
lex400sc
lex400sc's Avatar
You aren't by chance buying your Breytons from mahdi's classifieds ad are you? I would give that a second thought if I were you...
Old 05-22-03, 06:07 PM
SC300T
SC300T's Avatar
Once again, the lugs are 5x114.3, not 120.
Generally, the offsets need to be greater than 40, with 50 being the stock offset.
Old 05-22-03, 06:36 PM
marcman18
marcman18's Avatar
Where can I get an adapter to fit the Breyton wheels above? Does anyone know.
Old 05-22-03, 07:14 PM
killerlex
killerlex's Avatar
Default drill them
you need to order them drilled for your 5x114. or 10 hole rim.thats how people get the alpinas and carlson on there sc's.
Old 05-22-03, 09:26 PM
marcman18
marcman18's Avatar
Does anyone know where I can get Breyton 19s inpirations in a 5x114.3 fitting?
Old 05-22-03, 09:48 PM
Angel
Angel's Avatar
Lex Luthor, can I fit a 17x9.5" on the FRONT with +28 ?
Old 05-22-03, 10:08 PM
marcman18
marcman18's Avatar
Old 05-22-03, 10:09 PM
marcman18
marcman18's Avatar
In relation to above, Where can I get adapters or where can I get someone to make a custom drilling mod.
Old 05-22-03, 10:46 PM
lex400sc
lex400sc's Avatar
So pushy...
Why not just get wheels made for Lexuses? There are sooo many more JDM brands out there than Euro brands, and they all match better on Japanese carstoo. Unless you've come across a spectacuIar deal for the wheels already retrofitted for Lexus hubs (like $1000/set), what's the point in jocking them so hard? You'll probably end up spending more than it's worth making them work with your car. The Breyton Inspiration wheels are not all that great: one-piece cast aluminum--on the lower end of the wheel spectrum. Big deal. Besides that, it's kind of cheesy slapping AMG or AC Schnitzer wheels on a Lexus if you catch my drift. Breytons are no exception. Save yourself the trouble, you'll find it's even harder to resell them once you've bored them out for Lexuses only.
Quick Reply: 1992 SC400 Rim Size options
