SC- 1st Gen (1992-2000)
View Poll Results: I change my oil every......
I'm a crazy nut, I change my oil every 2,000 miles
9.23%
I go with the rules, I change my oil every 3,000 miles
42
64.62%
Too lazy to change so I change my oil every 4,000 miles
14
21.54%
I like to have bad MPG and black oil with a bad running engine. I change my oil every 5,000+ miles
4.62%
What? I have oil? I never change whatever it is your talking about...
0%
Voters: 65. You may not vote on this poll
How many miles do you change your oil on your SC?
Old 10-18-03, 11:25 PM
henrynguyen
henrynguyen's Avatar
Thumbs down Not True
this is not true!!!!!!
Originally posted by One HoT SC400
I think Peter Scott did a dyno and some research to see if synthetic would be a better choice for our cars...From his results, Mobil 1 was as good as any other oil out there that was non-synthetic (ex: regular Mobil oil)...He claims that as long as you are changing your oil on a regular basis (3,000 miles)..Your motor should be fine...
Now if I can find the thread on this ..eek1:
henrynguyen is offline
Old 10-19-03, 01:45 AM
sweetsc400
sweetsc400's Avatar
2500 - 3000, mobil 1 synthetic, pure one filter
sweetsc400 is offline
Old 10-19-03, 09:28 AM
dartdoc1
dartdoc1's Avatar
Every 3000 miles or 4 months whichever comes first w/ valvoline motor oil, mileage alone isn't the only reason to change your oil dirt,dust,condesation,ect.
dartdoc1 is offline
Old 10-19-03, 08:08 PM
Supra4100
Supra4100's Avatar
3000miles with mobil dino oil.. for the sc
3000 miles with mobil 1 for the supra
5000 miles with mobil 1 for the eclipse
3000 miles castrol gtx for the laser..
pure one filter for the dino oils and mobil 1 filter for the other 2
Just a side note changing the oil in the eclipse and laser is much more user friendly than those damn 2jz's
Supra4100 is offline
Old 10-20-03, 05:30 PM
Supra Dr
Moving SC Threads
Supra Dr's Avatar
mobil 1 only & dealer filters for the fleet
every 3000 or 6 mos.
my '87 turbo toyota tk. has 130k or so
& you can run your tongue down the rocker
arms its so clean (it been beatten on all its life)
coke & sludge kills a motor
Supra Dr is offline
Old 10-26-03, 10:45 PM
SDSC300
SDSC300's Avatar
Originally posted by sc400
I change my oil every 5K miles and I think it's very reasonable.
Newer cars today like the Cadilac or bmw do not need to change oil until the light indicator goes on, and that could be 10K.
you must be one of those that felll WAY off the tree you crazy monkey!!!
I change mine every 2k- 2.5k ... its cheap to change and can't hurt the car ... only pro-long the life.
SDSC300 is offline
Old 10-26-03, 10:53 PM
lex400sc
lex400sc's Avatar
I think every 2,500 miles is a waste of oil and filter. I don't mind you wasting your money changing so frequently, but oil is a commodity man! That stuff can last indefinitely and only really gets dangerously dirty around 10,000 miles under our conditions. 5,000 miles isn't a bad mileage to go by if you're trying to be frugal. I wouldn't go longer than that if you're aiming for longevity of the motor though.
lex400sc is offline
Old 10-27-03, 07:44 AM
RSTSpeed
RSTSpeed's Avatar
I change it every 3-4k, depending on when I have the time, using Castrol GTX... Uh, every 5-10k will KILL your car. Mine is living proof - owner before me change it every 8-10k, now I have fried piston rings and a main bearing on the verge of spinning. I'm lookiung for a new engine....hence the plea in my sig
RSTSpeed is offline
Old 10-27-03, 10:00 AM
NRG
NRG's Avatar
if you're talking about the maintance light.. that only comes on every 7k miles of the car from the time of being reset.
every 5k miles is when you're suppost to change your oil.
i do mines at 3k for the heck of it.
synthetic oil is bad for your car if your car has more then 80k miles.
i have so many people tell me how good it is, but always coming back saying they have problems. Because the oil leak through the seals and does lots of damage.
synthetic
it's only good if you have a new car. because your seals are good to withhold the oil.
Peter Scott can lick my nu**..
NRG is offline
Old 10-27-03, 12:37 PM
RSTSpeed
RSTSpeed's Avatar
WTF? Was that necessary?
RSTSpeed is offline
Old 10-27-03, 01:17 PM
sc4canada
sc4canada's Avatar
I go by the panflet at the dealership and I just use the dealership oil and also for other lubricants.
sc4canada is offline
Old 10-27-03, 07:11 PM
TGRich
TGRich's Avatar
synthetic
People, do not be misled by the uninformed.
I use synthetic with 113k and have no problems whatsoever. Using syn in your high mileage engine will not cause any problems. The worst that can happen is that is leaks a bit.
As for the Peter Scott comment, that was 100% uncalled for. Peter is a man for whom I have great respect. I don't know anybody else that does the extensive, scientific testing that he does. Not to mention the great website that he hosts http://planetsoarer.com/
TGRich is offline
Old 10-28-03, 10:05 PM
UZZ32
UZZ32's Avatar
Peter Scott can lick my nu**.. [/B]
Thankyou for the invitation NRG !
For a 3000 mile interval Mobil 1 had the same wear contaminants in my engine oil as regular oil. I paid money at a lab to get the oil samples analysed. Full oil analysis data sheets available here:
http://planetsoarer.com/OilAnalysis/OilAnalysis.htm
Oil starvation (sludging, blocked oil galleries from additives, low oil level) and overheating are big killers of engines
I don't know how people rate oil by looking at it during a change or other anecdotal evidence - I don't have those superpowers!
Didn't have any leak problems on my car. Common answers to leak problems are here:
http://www.bestsyntheticoil.com/amsoil/seals.shtml
The above site is sponsored by Amsoil.
Without a doubt full syn oil has some superior properties - I always change to full syn before a weekend of track sprinting.
With an extended drain period using full syn consider changing the filter at least more often than the oil. All the extended drain oils recommend this. The filter may clog and go into bypass mode long before the oil degenerates.
Oil always looks better on the dipstick. Oil that looks clear on the stick most often looks black and yucky when drained into a pan.
I change every 3000 miles or before a track session.
A 15W diesel oil also has an excellent additve package and is good value - check it out next time you are shopping for oil.
There are also many demonstrations for oil additives around nowadays - many of them use extreme pressure properties better suited to Hypoid gear oils (diffs for example) rather than low wear rate engine oils. There is evidence that certain additives are beneficial short term for gear boxes and pumps - but long term in a petrol combustion engine? - I haven't seen any.
UZZ32 is offline
Old 10-28-03, 10:52 PM
SC400TT
SC400TT's Avatar
I just passed 100 k miles on my car . I have been running Mobil 1 since 60 k miles. I change the oil and filter every 3 k miles- Mobli 1 5w-50 supersyn, and $15 Toyota top quality filter (switched from Pure 1 filter). I have no leaks- NONE WHAT SO EVER!!!!!!!!!!!!!! My garage floor is spotless, as are the brick pavers in my driveway. If your seals are in good shape, no oil will leak. If your seals are in rough shape, any oil will leak through.
NRG, As far as the comment you made to Peter Scott, well, that just proves the many other complaints and issues so many members on CL have had with you. Peter Scott is a credit to the SC400 community, and besides, I am sure he would much rather have an Aussie brew.
NRG, your lack of decency in this case is quite appalling.
Ryan
SC400TT is offline
Old 10-29-03, 01:38 AM
NRG
NRG's Avatar
its all good..
i love my rep on this forum.. Do i get an award?!
i wish i could find the time to do so much for an SC..
props to you scott..
alot of time and dedication to all your work.. *wonders when do you find time to have fun?*
NRG is offline
Quick Reply: How many miles do you change your oil on your SC?
