Custom Made Tail Light Color Mod
Kira X (07-22-17)
Do you think you could have the reverse lights manufactured? I would be more interested in that than the signal lens.
Awesome, Do you have any estimate of what the cost would look like?
I broke my tail light today trying to remove the key hole, so that was a bit of a set back on my project. It makes me wonder how many people would actually try to replace the lens if you did have them manufactured.
I was originally trying to approach it using scotturnot's method and using a razor blade to cut/pry at the same time, but I wasn't sure where the breakaway point was (now that i've broken it, I know exactly where to cut in the future). I got impatient doing that, and I remember the facebook groups saying to just heat them up and yank it out (big mistake). I posted the pictures in my build thread.
Should be around $100 range. We never take the key hole apart. We simply break the thin part that overlap from the reverse piece, it's behind the entire red part anyways, so it won't be seen. Once that thing is broken, we can bend the reverse part slightly to get it out.
$100 for a replica of the OEM lens with no UV damage sounds worth it to me.
yellowssm
03-16-06 09:40 AM
