SC- 1st Gen (1992-2000)
steering column vertical adjustment
Old 06-13-03, 02:28 PM
rcftx
rcftx's Avatar
Default steering column vertical adjustment
I am the original owner of a 1993 Lexus SC 400 with 46k on it. I loaned the car to a friend, who is a big guy, when I got the car back the steering wheel column vertical adjustment button produces a grinding noise with no movement. The telescopic feature works fine, however I want the vertical adjustment to work as original. Apparently a gear must have become stripped or something....does anyone know how to fix it? I would like to fix it myself if possible. I currently have the button in the manual mode to eliminate any vertical movement of the steering column until I get it fixed.
Old 06-13-03, 08:12 PM
kmn5
kmn5's Avatar
Dude, That is sick!
Do you also share your gf with your friends!??!?!
j/k
hmmm, does it only gring in one direction???
It's in the upmost position now, isn't it?
see if anything is wedge in there first
Old 06-13-03, 09:07 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
even if the guy didnt do anything to it at all, that's just life. run some tests to determine how it responds to different situations.
Old 06-13-03, 10:47 PM
rcftx
rcftx's Avatar
It grinds in both directions...however if I put some downward pressure on the steering wheel I can make it go lower. It is now in a moderately low level with the automatic button in the manual position.
Thanks for the concern...
rcftx
Bondgirl
07-23-18 12:11 AM
TexasDave
NX - 1st Gen (2015-2021)
07-08-18 12:47 PM
lex_ga
02-12-03 03:11 AM
stock300
12-25-02 06:22 PM
Quick Reply: steering column vertical adjustment
