Fixed antenna options.
Keeper of the light
no such thing as best on this because all antenna are tuned to a frequency band, then the ground determines strength. So provided you ground it properly the end result on what you use will determine what you want it to look like. In terms of mounting it’s just sheetmetal so if you have to unibit for a different base it’s pretty easy, though most are common size universal.
A replacement mast runs $20-30 for these units. The challenge is taking it apart and swapping out the broken mast with the new one. But, if you have those skills you do end up with a fully restored mast. I have done this twice - once on an '84 Cressida and then the '92 SC (which used nearly identical units) so the second time it went a lot faster.....
Others have jumped to the "stubby" style with mixed results. The FAQ thread should reference several of the various models that were implemented but you won't find a "best".... (too many opinions and no clear choice).
Since I was successful twice in replacing the mast I am biased in that being the best approach....
Modenaro (11-17-17)
One thing to also consider is that the stubby antennas get worse reception compared to the mast, from what I recall reading. But if you primarily listen to stations nearby it should not be an issue. Are you sure the issue isn't the mast?
The motor seems to still be working from what you mentioned earlier; just that it is stuck constantly on. Might have to do with the broken nylon feed maybe being stuck?
The mast has a long flexible plastic linear "gear" attached like a tail, which coils up inside the antenna assembly. These can become brittle and break, and the teeth can strip. In either case, the result is a motor system than can't detect the end of travel properly and will usually continue to run. It's been a couple of decades since I've taken a Toyota antenna apart, it seems like they have a relay box attached to the antenna assembly. I expect a bad relay/driver could also cause the problem, but I in my years as an installer in the 80's-90's the only power antenna failures I ever encountered were lots of broken masts and a couple of bad motors.
Because of the mounting location, it's easy to remove the whole thing and open it up to have a look. If the mast is stuck in the up position, you'd have to be very gentle feeding the mast down through the hole in the fender.
-Tim
-Tim
I don’t think there are any aftermarket or other antennas off other cars that look better than original. Mdx one is too bulky and square looking. I’d leave the stock one in place and approach it from another angle like aftermarket stereo with a Bluetooth or WiFi hookup where you can use your apps for music even local radio stations!!!
i hardly ever use a radio, I use my phone apps for everything smart
