SC- 1st Gen (1992-2000)
True Ice Blue / Red caps for the clusters !!
Old 10-23-03, 08:26 AM
  #406
Jasoneo5
Jasoneo5's Avatar
would this fit on my 91' LS400 also? ie, are they the same thing?
Jasoneo5 is offline
Old 10-24-03, 07:17 AM
  #407
LexusBiz
LexusBiz's Avatar
Hey OLT,
On the driver side switches, how did you remove the driver side window switch button off the base. I got the door lock and passenger side window buttons off the base, but no matter how much I fiddled with the driver side button, I was not able to remove it off the base.
The passenger window and door lock buttons easily slid off the circular tab in the middle of the switch. But the driver side window button is different (assuming becuase of the auto down feature).
Previous owner had spilled soda in the buttons, so I need to do a thorough cleaning. I see that the factory used 3mm green LED's to light up the buttons. You think swapping to blue 3mm LED's (1500 mcd / 34' View angle) would work in term of brightness. I am sure the green LED's have a different Vf then the blue LED's, so I guess we are also looking at having to replace the resistors on the switch circuit board.
Let me know what you think? Tryin to create a little weekend project for myself.
After you swapped me to blue cluster needles and AC/Radio unit, I've been on a Blue craze.
I NEED BLUE MAN!!!
Thanks
LexusBiz
LexusBiz is offline
Old 10-25-03, 01:19 AM
  #408
nextlevelcoupe
nextlevelcoupe's Avatar
hey 1last..got those cathodes fired up!!!! check this out with samples from nissan sylvia speedo/tach
https://www.clublexus.com/gallery/da...auges3-med.jpg the white one is from the LS400
https://www.clublexus.com/gallery/da...auges2-med.jpg i have not seen the blue cathodes yet but,i was told they are smaller in size and easier to manipulate into the dash... wil keep you posted though...
https://www.clublexus.com/gallery/da...auges1-med.jpg from L S400
nextlevelcoupe is offline
Old 10-25-03, 04:20 PM
  #409
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Biz, i havent done it. dunno (as far as the leds) the switch needs to completely removed and broken down.
Next, looks freaky man way too bright to drive with, especially at night. (noone wants to hit the dimmer switch )
O. L. T. is offline
Old 10-26-03, 07:44 AM
  #410
nextlevelcoupe
it's the same light from a stock LS 400 ....the only other issue is that it comes with some sort of metal covering around the tube -that warms up the bulb,so it turns on and stays on...(temperature sensitive to cold)
Old 10-27-03, 08:05 AM
  #411
Jasoneo5
Jasoneo5's Avatar
So is that a yes, these will fit on my 1991 LS400?
Jasoneo5 is offline
Old 10-27-03, 10:54 AM
  #412
O. L. T.
Keeper of the light
O. L. T.'s Avatar
You need to talk to walker about your LS.
O. L. T. is offline
Old 10-27-03, 03:26 PM
  #413
JohnnyTCEO
JohnnyTCEO's Avatar
O.L.T. Do you have anymore of the red covers for the dash board lights (#24) ? I would like to get the red ones since you say those looks the best right?
I have a question on the LEDs. Can you make them on the rest of the lights like the ones clear corner makes?
I am sure if you can make it alot more affordable then they can, there will be alot of buyers.
Thanks,
John
JohnnyTCEO is offline
Old 10-27-03, 07:45 PM
  #414
O. L. T.
Keeper of the light
O. L. T.'s Avatar
go to your local parts store and get the 24's
i've been quoted a million times saying i dont like cathodes very much. they only last 30,000 hours at BEST V/S 100,000 hours from an led. they are picky about temprature, they are fragile, and i just dont like them, obvious high cost also.
I don't hate them i just know a better way overall.
that's not relative, i don't make profit off this. i'm practicing (currently in the last stage of my EE degree, need experience)
O. L. T. is offline
Old 10-29-03, 02:05 PM
  #415
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Now this is pretty. I fired the blue led's into the NAK and did the voltage mod and here's what happened.
O. L. T. is offline
Old 10-29-03, 02:30 PM
  #416
Jasoneo5
Jasoneo5's Avatar
Who is walker? How can I talk to him? What is is screen name? Thanks,
-Jason Elcan
Jasoneo5 is offline
Old 10-29-03, 03:07 PM
  #417
O. L. T.
Keeper of the light
O. L. T.'s Avatar
it's in the sticky in the LS forum.
O. L. T. is offline
Old 10-29-03, 03:44 PM
  #418
mrshabo
mrshabo's Avatar
that blue came out nicer than i think it would. good work o.l.t
mrshabo is offline
Old 10-29-03, 04:29 PM
  #419
nextlevelcoupe
very nice
where is the white dash/white needle setup you were working on bro?
(also the white climate control-cathode lighting project you started..)
i can't wait to see what that looks like!
Old 10-29-03, 04:50 PM
  #420
SC400TT
SC400TT's Avatar
ONE:
That blue is absolutely, positively gorgeous!!!!!!!! Love it Is that the color you call Ice Blue?
Ryan
SC400TT is offline
Quick Reply: True Ice Blue / Red caps for the clusters !!
