SC- 1st Gen (1992-2000)
True Ice Blue / Red caps for the clusters !!
Old 04-27-06, 07:38 PM
  #1141
Ariyanna
Ariyanna's Avatar
OK Im going to see if I can make those cathodes work on my ES cluster and will post pics
Ariyanna is offline
Old 05-15-06, 03:35 PM
  #1142
SoarerJzz3
SoarerJzz3's Avatar
I was cleaning my guages removing dust and accidentally moved the fuel guage. Now it won't go back to the correct position. Thinking maybe if I filled up it would correct itself, it didn't. Is there a way to fix this?
SoarerJzz3 is offline
Old 05-15-06, 04:26 PM
  #1143
O. L. T.
Keeper of the light
O. L. T.'s Avatar
pull it off and set it back on.
O. L. T. is offline
Old 05-16-06, 11:01 AM
  #1144
SoarerJzz3
SoarerJzz3's Avatar
Thanks Well it looks like i'll be sending my cluster back in, I tore the foil on the back of the needle and now it doesn't light up . Is there a way to fix it, maybe??
Old 05-16-06, 09:02 PM
  #1145
93SC300.
93SC300.'s Avatar
my speedometer, tak, gas gauge and my temp gauge went out and i want to know how much those for white needles. are they hard to install???
93SC300. is offline
Old 09-30-06, 12:57 PM
  #1146
prettyjay
prettyjay's Avatar
Do you have any advise or where I can go to get the lights in the needles changed
prettyjay is offline
Old 10-13-06, 11:37 PM
  #1147
kan83
kan83's Avatar
Default Leds
this is what i did using LEDs
Attached Thumbnails True Ice Blue / Red caps for the clusters !!-img_2112.jpg
kan83 is offline
Old 10-13-06, 11:39 PM
  #1148
kan83
kan83's Avatar
Default Leds
here is another pik
Attached Thumbnails True Ice Blue / Red caps for the clusters !!-img_2103.jpg
kan83 is offline
Old 10-13-06, 11:48 PM
  #1149
O. L. T.
Keeper of the light
O. L. T.'s Avatar
I like that wood trim kit.
O. L. T. is offline
Old 10-17-06, 09:11 PM
  #1150
gsCrazy
gsCrazy's Avatar
the led mods at the beginning of this post are incredible!
my climate control button blacklights just died on the passenger side for my 1999 GS300. does anyone know the bulb size and if they are plug and play or would i have to solder these one?
if someone could let me know either via pm or on this page that would be great!
thanks.
gsCrazy is offline
Old 10-17-06, 09:38 PM
  #1151
O. L. T.
Keeper of the light
O. L. T.'s Avatar
they are bulbs and they are soldered.
O. L. T. is offline
Old 11-03-06, 10:49 AM
  #1152
Lucky SC
Lucky SC's Avatar
so to fully redo all of the lcd's besides the radio one because i put an aftermarket head unit in there... how many of these would i need and are they easy to install?
i'm thinkin the red would look very very sweet, how much would it cost me for you to go pick up some of those red ones for me and ship it to me?
thanks,
chase
Lucky SC is offline
Old 11-03-06, 10:53 AM
  #1153
Lucky SC
Lucky SC's Avatar
also would i be able to pick up any red dome, ignition, and door lights anywhere?
i've seen blue and white around
Lucky SC is offline
Old 11-04-06, 07:15 PM
  #1154
O. L. T.
Keeper of the light
O. L. T.'s Avatar
I've never seen anyone do red in their car in those spots.
O. L. T. is offline
Old 11-04-06, 09:05 PM
  #1155
Lucky SC
Lucky SC's Avatar
could you hook me up with blue then for the ac lcd and all the buttons around it?
Lucky SC is offline
Quick Reply: True Ice Blue / Red caps for the clusters !!
