Jalopnik article on the history of the Soarer Z20's 1G-GTE 2.0L I6-TT engine
This is a good read if you've ever wondered about the twin turbo inline six engine that Toyota and Yamaha designed during the 5M/6M/7M era well before the 1JZ was developed and before the concept of the 2JZ-GTE was even a viable possibility.
The most notable versions were the 1G-GTE 2.0L I6 with electronic fuel injection and parallel twin turbos (like a 1JZ-GTE has) making between 185-210hp and a 1G-GZE supercharged 180hp version for select automatic sedans. The Soarer Z20 series commonly had the 1G-GTE 2.0L and the 7M-GTE 3.0L as the high end option.
Today unless I'm mistaken it is still much more affordable in Japan to own a car with a 2.0L or smaller engine (or even more commonly a 660cc Kei vehicle) due to the tax structure.
Our JZ engines took *inspiration* from the high performance intended M-series engines of the 80's but even before the 1JZ-GTE came out you can see many early versions of its hardware that was first tried out in the 1G-GTE series.
https://jalopnik.com/toyotas-first-t...han-1824260905
The following 5 users liked this post by KahnBB6:
1997Soarer (04-05-18),
LEXXIUM (04-08-18),
RudysSC (04-11-18),
StoneBeige (04-06-18),
ThomasGS4 (04-05-18)
Wow! That truly a very interesting read! A lot of stuff were put into perspective there, like why Japanese companies are very conservative, I bet they still have some kind of laws prohibiting them to go "all out" to this day.
AdamLexus
Performance & Maintenance
04-25-08 09:55 PM
