Goin All Motor
Goin All Motor
ok......i wanna try this all motor thing before i do a gte or a na-t. i'm just wondering, what mods can i do besides the usual intake, exhaust, cam gears, headers can i do to get me in the low 15/14's??? so far i'm going w/ the JIC exhaust, HKS cam gears and i'm working on getting the XERD headers w/ some HKS cam gears. anything else you guys can help me with? like do i need a fuel management system? if so, whats the best? i've read bout some using the Motec and some using the Apexi. and would me buying a set of grounding wire/system help much??? get me back up guys...thanks for the help.
their are more to all motors then basic cams, intake, header, exhaust.
you should start from the inside out.
building the internals of the motor.
Running higher compression, forged pistons, valve job, etc.
not sure how it increases power, but supposedly it does.
buying a "kit" rather than just going to the store and getting the wire yourself and some terminals..... well, that's a difference in my opinion.
ok then.....question bout the fuel management situation...whats the best way i can go...apexi or a motech. heard pluses bout both of them but whats more....i dunno...efficient and would yeild the most power. and for the internals...arent the stock components good enough? since u all do turbo ur engines up on stock pistons and so forth. i dunno...fill me in here. port and polish......is a deff though.
Here's a list of what I would do if going all-motor. Intake (injen or a decent home made one), extrude hone intake manifold, under drive pulley's, electric fans, cam gears, xerd header, straight single side exhaust (no cats or a high flow one) , ignition wires/coil, and some kind of air/fuel management. Going n/a is gonna cost some bucks to do it right and the results won't be as spectacular as a turbo.
