Replacing taillight lamps
Does anyone with a service repair manual (or anyone with the knowledge) know how to replace the right taillight fixture on a 1994 SC300? If someone could post the steps to remove the original and install the new taillight I would really appreciate it! I've searched the archives and didn't come up with anything. I know this is probably a simple installation but I thought I'd check with you all first!
If you open up the trunk and remove the carpeting on the rear youll see 4 bolts on each side holding the lamps in you have to unscrew all 4 of those bolts. When you take out the lamp take a small hammer and hit lightly each one of those screws from the inside to get the lamp loose and then wooola
any bulbs that is brighter than original bulbs? My taillights are so dark (brake lights are ok).
I'm curious if I change to new aftermarket bulbs, it would do any brighter.
