antenna problem
When I turn on and turn off car the antenna motor runs but the mast never engages. Does it need a new motor? The motor sounds like it's running. New mast? Any advice is always appreciated. Thanks
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
You need a new mast, the plastic grip strip that helps retracts and extends the mast, has worn down. It's an easy fix. I have done about a half dozen of these fixes. And you can get a new Mast for $25.00 of off Ebay. If you need more info on Mast and fix, PM me, I will be glad to help!
