SC- 1st Gen (1992-2000)
Redline to early!
Old 07-20-03 | 01:41 PM
Philly#1 Lex's Avatar
Philly#1 Lex
Default Redline to early!
I was in Italy today on the highway and decided to floor it since i just got my new tires, weigh and balancing done. I was at 120mph and i was just about at the redline. I couldn't believe it. whats wrong. I have a 92 SC400 that just went over 50,000 miles. I am pissed I thought i could get faster. I need to know what needs to be done to go faster! Havent done my 60k service yet i have to do it myself becasue the SC400/ Soarer never made it here so no one works on them here that i can trust at least.
Philly
Old 07-20-03 | 04:30 PM
boredguy77's Avatar
boredguy77
did you have overdirve off? if it is off it will severly restrict your top speed.
Old 07-21-03 | 02:24 AM
Philly#1 Lex
yes i had overdrive and power off!
Philly
Old 07-21-03 | 02:31 AM
jet864's Avatar
jet864
Ok, by turning off the O/D it essentially downshifts when you are at higher speeds. This acts like a lower gear with a lower redline than your actual top speed. With O/D off the car will be good to around 125 then you wil have to turn it back on and go with normal O/D. Then you can hit about 150. Oh, I don't think power would affect your top speed anyways, pretty sure it controls your shift poins and control under WOT.
James
Old 07-21-03 | 02:39 AM
Philly#1 Lex
Thanks!
Philly
Old 07-21-03 | 02:43 AM
Fred Smith's Avatar
Fred Smith
OD off just stops it from shifting into top gear (which, funnily enough, is the overdrive gear at 0.705).
Just like if it had a "3" on the shifter. Turn OD on and now you enable 4th gear. Should be good to around 140-145.
Old 07-21-03 | 09:53 AM
boredguy77's Avatar
boredguy77
Yep, this is definately correct.
sherriff
Maintenance
11-04-06 04:28 AM
DJ LEX
01-01-03 01:56 AM
