some ?'s
some ?'s
i have a 93 acura legend coupe right now getting ready to selll it i think, and was thinking about gettin a sc.....which one would be better the 400 or the 300? could yall give me the pros and cons? and wut are some common problems with the sc's the legend has way to many problems that i care not to put up with anymore thanks alot
Keeper of the light
Welcome to CL. Please do a search for your questions as they have been discussed so many times you will find MORE than your fill of info on pro's and con's. even specific threads on V/S just like this. Thanks!
Glad you stopped by. Enjoy your stay.
problems some more common than others..
-power steering pump,
-some people times the high-pressure hose too
-leaking power steering rack
-Speedo lights and needles going out
-condensation in the head lights (re-seal them or replace)
-a/c compressors sometimes go out on at least the sc300 don't know about the sc4
-some problems with the power windows
-heard of some problems with the power seats.
-climate control bulbs burn out.
-door hinge's
-trunk supports
-12 disk cd changers - skips, doesn't play cd-r's or doesn't change cd's in some cases (mine was fine)
-bushings go bad and should be replaced
other things too =P I just can't think of them
problems that I personally had were:
main drive pulley broke replaced
power window switch went out.replaced
a/c compressor went out replaced
power steering pump needed to be resealed
high pressure hose needed to be replaced
manual tranny replaced
climate control light bulbs replaced
trunk supports replaced
headlights had condensation in them and need to be replaced
my bushings are going too.
-door hinge's
-trunk supports
Go 400 unless you truly are gonna turbo/supra swap your 300. 400 has more power, and just as luxurious as the 300. IMO, 5 spd 300 is the only SC300 worth getting.
James
James
On the flip side of the problems pointed out by SDSC300, remember, you get what you pay for. I agree about the 400 over the 300 but both have their positive point. Do a search like the men said since there are many opinions on CL. As to getting what you pay for, look at the service records, get the SC checked out by someone you trust and look for the defects SDSC300 mentioned. Me, I was really lucky since my 95 came from a home that cared for it and maintained it VERY well.
When you go shopping for your SC remember, cheap is not best and for a nickle more you can go first class. Just my $.02.....
Forum Administrator
Welcome!
I know there's a lot of material out there to search through, so I thought I'd put up a couple of threads for you to start with.
I searched using keywords like "which buy sc300 or sc400 best" and came across a few useful threads:
https://www.clublexus.com/forums/sho...threadid=47394
https://www.clublexus.com/forums/sho...threadid=89080
https://www.clublexus.com/forums/sho...threadid=86253
https://www.clublexus.com/forums/sho...threadid=81422
https://www.clublexus.com/forums/sho...threadid=79670
https://www.clublexus.com/forums/sho...threadid=53040
Oh, and good luck!
Oh, and good luck!
thanks alot fellas i recently bottemed out the front end of my legend and now i have to get ANOTHER new rad. couple new hoses new belt tranny mount and god knows wut else this is all from just me looking at the underside and in the engine bay.....so im gonna fix it up i.e. new leather, paint, and rims and sell it reall quick, im stuck between getting a gs 300 or an sc, i like the sc4's but wut about gas? i used to have a suv and i kinda hated hangin out at the gas stations then friends houses lol, im not really lookin to turbo the thing out just want a nice car, before i got my leg. i was lookin for an sc and i just thought which ever car i come across first ill go for it, so i got the ack. now im kinda regreting it, iv spent sooo much money but met some cool people and earned a good peice of mind from the experience. thanks for the help guys hopfully soon ill be able to post new pics of my new car soon.
drew
drew
http://www.intellexual.net/faq.html Check this website out it should help alot. Good luck at finding one.
acks2lex,
I had a 91 LS coupe 5-speed and then a 94 LS coupe 6-speed. What problems is your car suffering? To be honest, if your Legend has "way to many problems" that you can put up with your SCx00 will have just as many problems. And SCx00 problems tend to be more EXPENSIVE to repair. In any case, I get ~21-23mpg in 90% local / 10% freeway driving in my SC400 which was about the same as my 91 5-speed and a little less then the 24-26mpg in the 94 6-speed.
Good luck with your search and welcome.
Regards
Regards
-door hinge's
-trunk supports
-brushings go bad and should be replaced......(Brushing?)
my brushings are going too.
-door hinge's
-trunk supports
So I'll got back to a point made earlier, DID YOU BUY A BARGIN SC, and overlook these items or did they all come up/break while you owned the SC..... After you bought it in good condition.. Anyone out there thinking you're going to find a bargin cherry SC, good luck and keep looking..... Of course if in a divorce settlement that the wife is really pissed at the old man because he treated his SC better that her.... Sound familiar to anyone.....
